Registered members do not see this advertisement! Remove it by signing up for free.
buick forums
The Premier Community for Buick Owners and Enthusiasts
Join us! It's free!
buick forums
Past Lineup: Lucerne | Roadmaster | Regal (Old) | LeSabre | Century | Park Avenue | Riviera | Reatta | Grand National
Current Lineup: Cascada | Verano | LaCrosse | Regal | Enclave | Envision | Encore
Buick Forum: Need some help with my 2011 Buick Regal CXL
Results 1 to 5 of 5
  1. #1
    T. Welch is offline Buick Newbie My Buick(s): 2011 Buick Regal CXL
    Join Date
    Jan 2017
    Uhrichsville Ohio
    Posts
    Rep Power
    Sign up to remove this ad
    I'm new to using a forum, so work with me here. I am having some power door lock and driver door key lock issues and am trying to remove the drivers door panel without breaking anything. I have been unsuccessful in finding any videos on You Tube to help with this. Can anyone tell me how to remove it with as little damage as possible?
    Thank you.
  2. #2
    Join Date
    Jan 2016
    Posts
    144
    Rep Power
    Re: Need some help with my 2011 Buick Regal CXL
    You have to use a small tool to pry two trim panels off the door: one behind the door release handle, and the other is the silver-y front cover over the door pull handle. There is one screw behind the release handle trim and two screws behind the pull handle trim. Once these three screws are removed the rest is just plastic push-pins, so just start pulling/prying around the outside of the door pad gently to release them all, and then it is just "hooked" over the top by the window, so lift up. Then of course there's just the electrical connectors.
    I have this all with pictures in PDF form that I can e-mail you if you want to Private Message me your e-mail address also.
  3. #3
    Join Date
    Jan 2017
    Uhrichsville Ohio
    Posts
    Rep Power
    Thank you! They hide this stuff pretty good, and me and plastic parts that i'm not sure how they come apart don't usually don't get along too well and things get broke. The information you gave me was very helpful. Thanks again!
  4. #4
    Join Date
    Jan 2016
    Posts
    144
    Rep Power
    No problem! It's pretty easy to break plastic parts if you don't know what needs to come off - interior trim pieces aren't too forgiving when it comes to trial and error.
  5. #5
    jagnweiner is offline Buick Newbie My Buick(s): 2012 Buick Regal GS
    Join Date
    Dec 2016
    Posts
    11
    Rep Power
    Remove this ad
    Also, for less than 10 bucks at autozone, you can get a set of plastic pry tools designed specifically for prying off various interior parts without damaging the finishes. Better than using screwdrivers and metal pry bars.
    Edit: Apparently $18 at Autozone, although the same set is $9 at harbor freight. http://www.autozone.com/test-scan-an...?checkfit=true
    Regards,
    Scott
    2012 Regal GS 6MT
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Buick? Check out your options at the links below:
Genesis Motors
