03 Lesabre won't start.
Debra
2003 Lesabre
Hey y'all. My sister's car isn't playing nice at all. Turn the key, it just clicks. Battery is good, just got done replacing the starter. I've checked fuses, checked ground wires, as well as I could find them. Any thoughts?
291
How do you know the battery is good, have you had it load tested? Are both the battery connection clean & tight?
Debra
2003 Lesabre
Connections are both. I did notice when I checked the maintenance book I keep its been longer than I realized since I had it tested, so it's going tomorrow. However, I did attempt to start it in neutral which I hadn't even thought of, and she tried. Thank you for answering, I really appreciate it.
291
Sounds like the battery is DOA! How old is the battery?
291
Do you have a meter to test the volts? If it is below 12v, it is nearly dead! 12.67v is a full charge. That does not mean that the battery will pass a load test.
728
Jump starting the car may be a option to consider and confirm it's the battery or something else.
Homer Jay
42
New York
2001 LeSabre
I believe if the engine cranks but will not start, the security system is not the problem. Check for spark and fuel.
728
Fuel, air, spark, computer and unfortunately if any one of those has a issue it's. Toss in a unkown gremlin and it's back to basic troubleshooting each system. Trying another ignition key on some cars works and not on others.
Start with spark, then fuel and then air. Was the CEL on before not starting? A clogged fuel filter will cause a no start also.
Debra
2003 Lesabre
Its getting fuel, I checked that. Tried checking for spark, got a loud ' pop ', and I jumped, but didn't see a spark. It could have, but I was jumping back.
Homer Jay
42
New York
2001 LeSabre
Before you replaced the starter did the engine run without any issues? If this is a new problem recheck your work, recheck related fuses in the engine compartment and under the back seat.
Debra
2003 Lesabre
I'd pulled the starter to get it tested because all I was getting was clicks. It tested as good, but then I dropped it on concrete and had to buy a new one. I also realized I'm going about this backwards. We were on the highway when she just stopped working. Cruised to the shoulder and had to tow her home. What could do that?
