'15 Regal Turbo USB Input
dnoel01
New Hampshire
2015 Regal Turbo Premium FWD, 2015 Encore Premium AWD, 2005 LaCrosse CX
Can anyone tell me why none of my flash drives will play on my '15 Regal audio system? The Intellilink does not even recognize that there is a USB media device plugged in, yet these same flash drives play fine in both my '15 Encore and my friend's '15 Chevy Cruze. Any help would be much appreciated.
dnoel01
New Hampshire
if you plug in a phone, does the phone recognize it is being charged?
Yes, it recognizes a phone and will charge devices. But it will not play music WMA or MP3 files from a flash drive, regardless of whether it is formatted as NTSF or FAT32.
564
Unfortunately it's seems as if you have tried all the basic trouble shooting with the flash USB port. Seeing how you know on the two formats and I'll assume that they don't have any other files other than music.
There are some TSB out there on these types of issues, but that may require a dealer trip or call with the VIN number to see about software updates. The only wildcard is that the USB port or cable could be a problem, but seeing how your phone is being recognized and able to playback it's not likely.
mrharrelson@yahoo.com
46
Annandale, VA
2012 Buick Regal GS
Morning guys,
I also have this issue, phone will charge when I connect the cable to the USB port but car display says can't support it. When I have my phone or camera connected to the USB port, my rear speakers don't work it i have my phone plugged into the AUX port.
Here is the reply I got from the dealer on the matter:
G# CUSTOMER STATES THE USB PORT IS STATICKY WHEN USED
Verified concern. Found USB receptacle to be malfunctioning. New receptacle will be needed. Parts and labor will be covered by the Fidelity extended service contract however the cost of the repair would be less than the $250.00 deductible.
Correction to be taken per customer approval. Cost $190.00
dnoel01
New Hampshire
Hey everyone sorry for the lengthy delay in responding. I did finally take the vehicle to the dealer to investigate the problem further. Turns out that there was a short in the USB interface that was allowing charging but not the recognition of a flash drive or the ability to play files from it. The USB was replaced completely under warranty and is functioning perfectly now. You gotta love the extra coverage of a standard 4-year/50,000 mile bumper-to-bumper warranty. Just another plus for Buick!
craigffb
A Regular
75
Clarksville TN
2012 Regal GS, 2005 Pontiac GTO, 2017 Durango R/T
Does your USB port have the SD card slot in it and if so is there a part number for what they replaced?
Thanks
dnoel01
New Hampshire
Hi. My connections under the console lid are two USB ports, an aux mini jack and the SD card slot you mentioned. I checked my repair order but there is not a part number listed for what was replaced. Sorry for the lack of info.
craigffb
A Regular
75
Clarksville TN
Thanks. On a side note, mine only has 1 USB so it would probably have been different anyway.
