Some banned guy
- 6
- 8
- Buick
The vast majority of these Manuals are ATSG (Automatic Transmission Service Group) Manuals and would generally cost between $25 to $50 EACH !!
Most of these are for vehicles older than 10-15 years, but seriously, if the one you need isn't here I'd be surprised.
Here is the main goal:. EVERYONE copy this text and paste it into a new text file or Microsoft Word file.
(EDIT)
THE WEBSITE HAS A LIMIT OF 20,000 CHARACTERS, SO I COULD NOT POST THE ENTIRE LIST. THEREFORE I DELETED WHOLE CHUNKS AT A TIME UNTIL IT WOULD ALLOW IT TO GO THROUGH. AND SO I ALSO ATTACHED THE ORIGINAL TEXT FILE TO THIS POST. SO IF YOU SAVE THE ATTACHMENT YOU WILL HAVE THE COMPLETE LIST TO USE FOR DOWNLOADING THEM AS WELL AS POSTING ELSEWHERE. THANKS AND SPREAD THE INGFO !! (/EDIT)
Start creating folders and sub folders and download them ALL whether you need them or not, it actually takes less than 1 gigabyte of hard drive space.
Then later down the road when you know of aomeone that really needs some of them, you could burn just the Big 3 Auto Makers onto one regular old CDR and hand it to them.
THEN those that are members of other GM forums or ANY other Brand like Ford, Mopar, Nissan, Toyota Etc. Repost it on as many other forums as possible so everyone can get the entire library. C-Mon, I know you drive a Buick, but I also know it is very likely there is a different Brand in your driveway as well or even within the circle of family and friends.
The ATSG repair manuals contain a lot more information beside exploded views and step by steps, they also contain electrical diagrams and troubleshooting info as well. They are truly handy to have. So without any more of my ongoing drivel, Here It Is. It is fairly long so be prepared.
MOPAR MOPAR MOPAR MOPAR CHRYSLER CORPORATION MOPAR MOPAR MOPAR MOPAR MOPAR
RWD:
---------------------------------------A727 Based:
A727 (36RH)(37RH) 62-94 + A904 (30RH)(32RH) 60-02 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/A727.pdf
A518 (46RH) 92-03 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/42RH.pdf
46RE/47RE/48RE 2011 Manual https://shop.ukrtrans.biz/wp-content/uploads/catalogs/46RE.pdf
A618(47RH) 94-03 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/42RH.pdf
48RE (A818) 03-07 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/48RE.pdf
--------------------------------------A904 Based:
A904 (30RH-32RH) 60-02 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A904.pdf
30RH/32RH JEEP, ANOTHER A904 MANUAL https://wranglertjforum.com/attachments/30rh-32rh-automatic-transmission-pdf.14090/
A500(42RH) 88-04 Rev.1992 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A500.pdf
42RH (A500)/46RH (A518)/47RH(A618) http://shop.ukrtrans.biz/wp-content/uploads/catalogs/42RH.pdf
42RE (A500SE ) https://shop.ukrtrans.biz/wp-content/uploads/catalogs/42RE.pdf
A904T + A999 UPDATE 1986 With TC,VB INFO. This One Is Must Have http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A999.pdf
45RFE 99-03/ 545RFE 01-11 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/45RFE.pdf
45RFE/545RFE FSM? http://shop.ukrtrans.biz/wp-content/uploads/catalogs/545RFE.pdf
68RFE 07-Present https://shop.ukrtrans.biz/wp-content/uploads/catalogs/68RFE.pdf
AW4 87-93 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/AW4.pdf
5G-Tronic (722.6)(Chrysler NAG1) 02- Present
W5A330 03-07 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/722.6.pdf
W5A380 " "
W5A580 05-Present " "
W5J400 JEEP http://shop.ukrtrans.biz/wp-content/uploads/catalogs/722.6.pdf
FWD :
It Really SUCKED What I Went Through To Find Out All 3 Entries Below Are Identical Manuals !!!
If You Will Notice, All Three Have A Different URL As The Numbers At The End Are Not The Same.
A404(40TE-41TE)/A413(31TH)/A415/A470 (81-87) http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A404.pdf
A404/A413/A415/A470 ATSG SERVICE MANUAL http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A413.pdf
A470 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A470.pdf
A413(31TH)/A670 ATSG http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A670.pdf
A604 (40TE-41TE) http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A604.pdf
LONGDITUDINAL FWD:
Engine Straight, But FWD Kind Of Fun To Think About Using In Something Wild. Like A Mid Engine SandRail !! lol
A604 (40TE/41TE) LFWD 89-10 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/41TE.pdf
The Two Below Are Also The Exact Same Even Though The URL's Are Different.
A606 (42LE) LFWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A606.pdf
42LE (A606) 93-04 LFWD https://shop.ukrtrans.biz/wp-content/uploads/catalogs/42LE.pdf
42RLE (03–12) LFWD https://shop.ukrtrans.biz/wp-content/uploads/catalogs/42RLE.pdf
A604 (41AE) 91-04
JEEP:
AW4 RWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/AW4.pdf
GM GM GM GM GM GM GM GM GM GM GENERAL MOTORS GM GM GM GM GM GM GM GM GM GM
GM: RWD
TH180/TH180C (3L30?) Delorean
http://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH180.pdf
TH200-4R 81-90 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH2004R.pdf
TH200/TH200C 76-87 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH200C.pdf
TH350 68-84-TH350C 79-84 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH350.pdf
TH375/TH375B 72-76 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH375B.pdf
TH400/3L80 64-92 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH400.pdf
TH700R4 (4L60) REBUILD PROCEDURES https://www.uscars.biz/uscars/extras-documents/ATRA_GM_4L60-4L60E_(700R4)_Rebuild_Procedures.pdf
TH700R4 (4L60) UPDATED MANUAL http://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH700R4.pdf
4L30-E (ML4) http://shop.ukrtrans.biz/wp-content/uploads/catalogs/4L30E.pdf
4L60/4L60E Gr8 New ATRA http://shop.ukrtrans.biz/wp-content/uploads/catalogs/4L60.pdf
4L60-E ATSG https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4L60E.pdf
4L60-E/4L65-E ATSG UPDATE HANDBOOK http://shop.ukrtrans.biz/wp-content/uploads/catalogs/4L60E_UPDATE_HANDBOOK.pdf
4L60E-65E/4L80E-85E DIAG CODES AND SHOOT GUIDE 185 Pgs https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4L60E_80E_CODE_BOOK.pdf
4L80-E https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4L80E.pdf
4L40E/5L40E/5L50E (M22) https://shop.ukrtrans.biz/wp-content/uploads/catalogs/5L40E.pdf
6L80 / 6L90 06- http://shop.ukrtrans.biz/wp-content/uploads/catalogs/6L80.pdf
Allison 1000/2000 Series http://shop.ukrtrans.biz/wp-content/uploads/catalogs/ALLISON.pdf
GM FWD:
TH125/TH125C (3T40) 80-99 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH125C.pdf
TH440-T4 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH440T4.pdf
4T40-E https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4T40E.pdf
4T60-E https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4T60E.pdf
4T65-E 95-10 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4T65E.pdf
4T65-E UPDATE HANDBOOK TO ABOVE MANUAL https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4T65E_UPDATE_HANDBOOK.pdf
4T80-E 93-10 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/4T80E.pdf
AF33-5 2004 GM INTRODUCTION TO http://shop.ukrtrans.biz/wp-content/uploads/catalogs/AF335.pdf
Saturn TAAT https://shop.ukrtrans.biz/wp-content/uploads/catalogs/TAAT.pdf
FORD FORD FORD FORD FORD FORD FORD FORD FORD FORD FORD FORD FORD FORD FORD FORD
------------------------------------------- FORD RWD:
C6 66-96 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/C6.pdf
C3 74-89 SUPPLEMENT http://shop.ukrtrans.biz/wp-content/uploads/catalogs/C3.pdf
C5 82-87 Improved C4 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/C5.pdf
A4LD=C3-OD 85–94 htps://shop.ukrtrans.biz/wp-content/uploads/catalogs/A4LD.pdf
E4OD 89-96 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/E4OD.pdf
E4OD UPDATE HANDBOOK http://shop.ukrtrans.biz/wp-content/uploads/catalogs/E4OD_UPDATE.pdf
4R100 98-04 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4R100.pdf
4R100 UPDATE HANDBOOK http://shop.ukrtrans.biz/wp-content/uploads/catalogs/4R100_UPDATE_HANDBOOK.pdf
4R44E/4R55E https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4R55E.pdf
5R55-E 97-01 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/5R55E.pdf
5R55-N https://shop.ukrtrans.biz/wp-content/uploads/catalogs/5R55N.pdf
5R55-W/5R55-S https://shop.ukrtrans.biz/wp-content/uploads/catalogs/5R55S.pdf
AOD 80-93 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/AOD.pdf
AOD-E See Also 4R70W https://shop.ukrtrans.biz/wp-content/uploads/catalogs/AODE.pdf
AOD-E/4R70W/4R75E/4R75W UPDATE HANDBOOK https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4R70W.pdf
E4OD 89-96? http://shop.ukrtrans.biz/wp-content/uploads/catalogs/E4OD.pdf
---------------------------------------- FORD FWD
ATX FWD Revised Edition http://shop.ukrtrans.biz/wp-content/uploads/catalogs/ATX.pdf
AXOD 86-91 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/AXOD.pdf
AXOD-E (AX4S) 91-93 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/AXODE.pdf
AXOD/AXODE(AX4S) UPDATE HANDBOOK https://shop.ukrtrans.biz/wp-content/uploads/catalogs/AXOD_UPDATE.pdf
AX4N/4F50N 94-07 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/AX4N.pdf
4F20E(RE4F04A) 93- Also Nissan http://shop.ukrtrans.biz/wp-content/uploads/catalogs/4F20E.pdf
F4EAT, F4E-III 90-03/ MAZDA F4AEL ATSG http://shop.ukrtrans.biz/wp-content/uploads/catalogs/F4AEL.pdf
GF4EAT 93-? SEE Mazda GF4A-EL http://shop.ukrtrans.biz/wp-content/uploads/catalogs/GF4EAT.pdf
CD4E 94-07 Mazda LA4A-EL https://shop.ukrtrans.biz/wp-content/uploads/catalogs/CD4E.pdf
5R110W 2003.5-10 https://shop.ukrtrans.biz/wp-content/uploads/catalogs/5R110W.pdf
4F27E 00-13 SEE Mazda FN4A-EL https://shop.ukrtrans.biz/wp-content/uploads/catalogs/4F27E.pdf
4F27E (Mazda FN4A-EL) Operation, Diagnosis, Wiring, Etc. https://shop.ukrtrans.biz/wp-content/uploads/catalogs/FN4AEL.pdf
---------------------------------------------- (LONGDITUDINAL FWD) LFWD:
4EAT FORD, MAZDA SUBARU, AWD Intro-Overview http://shop.ukrtrans.biz/wp-content/uploads/catalogs/4EAT.pdf
4EATG 89-97 See Subaru, Mazda: http://shop.ukrtrans.biz/wp-content/uploads/catalogs/F4AEL.pdf
IMPORT VEHICLE AUTOMATIC TRANS:
AISIN:
TR60SN (VW 09D,TOUAREG, AUDI Q7,PORSCHE CAYENNE) http://shop.ukrtrans.biz/wp-content/uploads/catalogs/09D.pdf
TF60SN (09G/09M) VW, AUDI) FWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/09G.pdf
AISIN WARNER TRANSMISSIONS :
DAEWOO, ISUZU, JEEP, SAAB, SUBARU, TOYOTA, VOLVO,
AW50-42LE FWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/AW5042LE.pdf
AW50-42LE DIAGNOSTICS https://www.volvoclub.org.uk/tech/service/850/AutoTransDiagnosis.pdf
BMW:
ZF-5HP19FL RWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/ZF5HP19FL_ATSG.pdf
BORG-WARNER TRANSMISSIONS:
BW65-BW66 BMW-JAGUAR-PUGEOT http://shop.ukrtrans.biz/wp-content/uploads/catalogs/BW65.pdf
ISUZU/TOYOTA
3080-LE (AW30-80LE) RWD ALSO TOYOTA A340E,A340F,A340H,341E DIFFERENCES http://shop.ukrtrans.biz/wp-content/uploads/catalogs/AW3080LE.pdf
JATCO TRANSMISSIONS:VEHICLES USED UNKNOWN:
----------------------------------------------- RWD
JR403E RWD BIG TRUCKS GMC,ISUZU,MAZDA,NISSAN,MITSUBISHI http://shop.ukrtrans.biz/wp-content/uploads/catalogs/JR403E.pdf
JR710E(Nissan-Infiniti RE7R01A) Tech Service Info http://shop.ukrtrans.biz/wp-content/uploads/catalogs/JR710E.pdf
---------------------------------------------- FWD
JF404E(NissanRE4F04B/A)FWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/RE4F04B.pdf
JAGUAR-LAND ROVER JF506E, MAZDA JA5A-EL, VW 09A: https://shop.ukrtrans.biz/wp-content/uploads/catalogs/JF506E.pdf
JF506E/JA5A-EL/09A UPDATE HANDBOOK https://shop.ukrtrans.biz/wp-content/uploads/catalogs/JF506E_UPDATE.pdf
JR507E/JR509E Used As SUBARU TG5C/TG5D "5EAT"
5R05 Used As INFINITI RE5R05A And A TON Of Others.
KIA:
A4CF2 KIA FWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A4CF2.pdf
MAZDA:
RC4A-EL http://shop.ukrtrans.biz/wp-content/uploads/catalogs/RC4AEL.pdf
F4AEL SEE Also FORD 4F27E http://shop.ukrtrans.biz/wp-content/uploads/catalogs/F4AEL.pdf
G4A-HL, FWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/G4AHL.pdf
G4A-EL/GF4EAT http://shop.ukrtrans.biz/wp-content/uploads/catalogs/G4AEL.pdf
GF4A-EL SEE Ford GF4EAT http://shop.ukrtrans.biz/wp-content/uploads/catalogs/GF4EAT.pdf
JF506E FWD https://shop.ukrtrans.biz/wp-content/uploads/catalogs/JF506E.pdf
JF506E FWD UPDATE MANUAL https://shop.ukrtrans.biz/wp-content/uploads/catalogs/JF506E_UPDATE.pdf
MERCEDES:
722.3-722.4 RWD 1991 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/722.4.pdf
722.3-722.4 RWD 2003 http://shop.ukrtrans.biz/wp-content/uploads/catalogs/722.3.pdf
722.5 RWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/722.5.pdf
722.6 RWD http://shop.ukrtrans.biz/wp-content/uploads/catalogs/722.6.pdf
722.7 In Russian!! http://shop.ukrtrans.biz/wp-content/uploads/catalogs/722.7.pdf
722.9 ATRA BASIC INFO http://shop.ukrtrans.biz/wp-content/uploads/catalogs/722.9.pdf
(EDIT)
RWD:
W5A380 " "
FWD :
LONGDITUDINAL FWD:
A604 (41AE) 91-04
JEEP:
GM: RWD
GM FWD:
AISIN:
BMW:
ISUZU/TOYOTA
KIA:
MAZDA:
MERCEDES:
