1971 buick skylark convertible
Phil911s
1971 BUICK SKYLARK CONVERTIBLE
I picked up this skylark a few months ago in Indiana and I love it...what I would like advice on is the suspension, its all original and for me the car sits too low..so do I do an entire suspension upgrade or I've be told I could use big block springs all around....any suggestions???
182
Do you have a "big block" engine? If not, the springs would be heavier that an original small block. It all depends on what you want the ride & height to be!
Phil911s
no its a 350 but I do like a higher ride height...would you think the car would sit high in the front?
Zeroboostbuick
244
S.W. Ontario Canada
I think the only 3 engines available in the 71 Skylark..
250ci (4.1 L) inline 6 cyl.
350ci (5.7 L) V8
455ci (7.5 L) V8
Very nice car you got there.
189
this isnt a Chevrolet, the 350 and the 455 use the same springs based upon information at www.eatondetroitspring.com .
You provided no full side view of the car so it is hard to tell how it is sitting.
How much stuff is in the trunk?
Phil911s
yes its a Buick 350 the main difference is the distributor in the front of engine...ill post more pictures later today.Mel I did check out your link for the springs thanks and if im understanding it correctly it seems like I can add inches to the springs to adjust height.
182
"Buick Skylark GS has 7 different combinations of year, body style, and engine sizes for you to choose from.
Your suspension's design depends entirely on your vehicle's weight. The same vehicle with a different body style or engine size may require different springs."
Springs For Buick Skylark GS - EATON Detroit Spring
LARRY70GS
79
48
Oakland Gardens, N.Y.
98 Riviera, 70 GS455 Stg1
Phil,
Very nice car. The there was only about a 150 lb difference between small and big block Buick engines (450 vs 616). Based on what I can see, looks like stock ride height to me. This chart from the 1970 Chassis manual should help. I'll add the one from the 1971 Chassis Manual as well, a bit different, not much.
I invite you to visit www.v8buick.com
Phil911s
thanks for all the help.. I took a side pick of how the car sits now and one with a jack under it, I raised it 1.5'' and I like it there so it looks like I can add 1.5'' to the rear springs on the EATON DETRIOT SITE …I was under the car today and I think I need to replace all steering and suspension bushings its just too loose. any recommendations where to order from? lol I could go on and on but another thing im not crazy about is the front grill..i think the 1970 gs grill is the best looking for this body but will it bolt up?
Phil911s
Larry I did compare height measurements and its on the money at stock height....so I am going to raise it abit
LARRY70GS
79
48
That's OK, looks good. You can order everything for the car from www.rockauto.com
1970 BUICK SKYLARK 5.7L 350cid V8 Steering Parts | RockAuto
Yes, the GS grill will fit, but it will cost you. The hood nose trim is different for the GS, but the Skylark one will work. There is also trim that fits on the GS grill. Those pieces do not usually come with the grill. I forget what that trim is called.
Phil911s
Thanks Larry.....
Phil911s
so I did replace the rear springs and shocks..i ordered them from Eaton springs, it was easy and I like how the car is sitting now but does anyone have alignment specs for a 71 skylark?
Phil911s
thanks
