1990 Reatta fuel problems
Warpedtek
1990 Buick Reatta
So when I test my 1990 Buick reatta fuel pump at the wire when the vehicle is off I get the correct amount of fuel pressure but when the vehicle is running I only get about £36 of pressure I have replace the fuel pressure relay I have replaced the fuel pressure regulator I have replaced the fuel pump with a brand new Delphi pump and I still can't get the correct amount of pressure to make my car run right
218
even though you replaced the pump and regulator they could be defective but you make no mention of whether you replaced the fuel filter?
