1990 riv front suspension
wayne scott
Hi does anybody have the factory specs for the front suspension caster camber toe in /toe out
fitted new struts and springs had 4 wheel alignment, car slowly goes towards the curb (left) when steering wheel is let go.
The car is used on UK roads so the specs need to be changed from American to UK. The alignment shop only has minimum and max figures anywhere between minimum1 deg 18 sec to maximum 3 deg 18 sec
Front wheels have been changed side to side but still pulls slowly to the curb.
If I have the original specs I could just swap the figures over.
LARRY70GS
548
Oakland Gardens, N.Y.
98 Riviera, 70 GS455 Stg1
Hi Larry thank you for the link, already read this some where before but it only give the minimum and maximum what I need is the factory setting. Again thanks
If you are serious about keeping the car, invest in the Buick Chassis Manual,
There will be a more involved table for alignment specs.
wayne scott
Cheers I will look on ebay see if there is one for sale
wayne scott
Hi Lar
Hi Larry just bought the one on the link you supplied cheers
