SOLD 1993 Roadmaster Estate Wagon White Woodgrain Delete NorCal
Status
Not open for further replies.
Yeahoo Whoyah
12
El Dorado Hills California
1993 Buick Roadmaster Wagon
REPAIR RECORDS
218,872 10/04/2018 FOUR NEW TIRES 225/65/R17
218,226 03/09/2018 TBI GASKET, AIR FILTER, WIPER BLADES
218,163 03/09/2018 NEW EMERGENCY BRAKE CABLES
218,101 02/20/2018 FRONT BRAKE ROTORS, PADS, WHEEL SEALS, REAR BRAKE SHOES, WHEEL CYLINDERS, RE-SURFACED DRUMS, BRAKE FLUID FLUSH,
217,200 10/19/2017 NEW BATTERY
216,500 (est.) 08/?/2017 REBUILT TRANSMISSION E&D AUTOMOTIVE
207,148 07/07/2015 UPPER & LOWER CONTROL ARM BUSHINGS
206,890 06/22/2015 R&R REAR SPRINGS, 4-SHOCKS, LOWER BALL JOINTS, WHEEL BEARINGS, DROPPED SPINDLES
203,418 03/??/2015 PURCHASED BY MIKE JOHNSON (STOCKTON)
193,305 10/11/2011 IDLER ARM
190,000 (est.) 05/19/2011 INTAKE MANAFOLD GASKET SET
184,000 (est.) 07/05/2010 FUEL PUMP, FUEL SENDER ASSEMBLY
181,954 01/29/2010 OIL COOLER HOSE
180,722 12/10/2009 ALTERNATOR
180,289 10/18/2009 WATER PUMP
173,000 (est.) A/C COMPRESSOR KIT
161,428 07/23/2007 POWER ANTENNA ASSEMBLY
157,570 02/22/2007 RADIATOR, OIL COOLER LINE, SERPENTINE BELT
103,941 01/02/2003 RMFG STARTER & SOLENOID
70,000 (est.) 02/13/2001 DASH COVER
68,172 01/06/2001 sold to WILL SMALL by MOORE BUICK/PONTIAC/GMC LOS GATOS OTD price $15,290
OLDER RECORDS MISSING
I spoke with a previous owner, Mike Johnson (from Stockton) who’d purchased this RMW in 2015 from Will Small (from Roseville). Will bought it in 2001 from Moore Buick. Mike said that Will had a new (or rebuilt) engine installed at John L. Sullivan Chevrolet. (!??). I asked if he had receipts and he said no because he tossed them out along with quite a few other records. Unfortunately, records are only kept for 2-years according to the Service Department at John l. Sullivan Chevrolet. So…. Caveat emptor
Status
Pedal Commander
