kyleGChiker
- 5
- 3
- 1997 Buick LeSabre Limited
I had a decent coolant leak, and the mechanic said the plastic elbows were urgent, but the upper intake manifold gasket and valve cover gaskets also had leaks. I can't remember if he mentioned about the lower intake manifold gasket or not. I had him do the aluminum elbows and I wanted to do some research on the rest. After a week of studying online in my free time, I decided this would be a great opportunity for me to learn a lot and do this repair myself!
I've read through all the forums here and watched a bunch of people doing this repair on Youtube, so my confidence level is definitely higher, but I want to make sure I have all the parts I need. Here's what I've ordered.
Other items I'll need to pick up locally:
Lastly, regarding tools, anything out of the ordinary I need to get for this job? I have screwdrivers, ratchet set, 3/8" drive extensions, torque wrench, oil filter wrench, but that's about it.
Assuming I've got everything I need, I'll probably do the job in a week or two. I'll keep you guys posted, and definitely may need some help once I get into the thick of things.
Thanks!
Description | Part Number |
Upper Intake Plenum w/ Gasket | Dorman 615-180 |
Lower Intake Manifold Gasket (aluminum) | FEL-PRO MS98014T |
Valve Cover Gasket set | FEL-PRO VS50080R |
Valve Cover grommet set | FEL-PRO ES72833 |
Coolant Bypass Gasket (not 100% sure I needed to buy this) | FEL-PRO 36021 |
Throttle Body Gasket | Mahle G31596 |
Oil filter and drain plug gasket | AC Delco PF47E & FEL-PRO 70820 |
Permatex Blue Threadlocker | Permatex 24200, 6 ml |
More shop rags |
Oil |
Coolant - is universal coolant fine? I plan to do a coolant flush and fill with distilled water, run a little bit, then drain the water and switch to coolant |
A few cans of brake cleaner/carb cleaner - which is better for this job? |
Thanks!
