1997 LeSabre Whining/Whirring Noise
Buikckforever
LeSabre 2001
Hello! I have a 1997 Buick LeSabre at Home, I really love these Cars. However, I noticed a whining or whirring sound coming from the Engine That reminds me of a Car That is driving in Reverse. the Pitch of the Sound gets higher once the rpm increase, it Starts a few seconds After the First cold start of the car. The Check Engine Light goes off immediately once the Car is fired up. There is a Link below where you can Listen to the car…
has Anybody of you experienced a similar Noise? Could it be something serious? Timing Chain or a belt or something?
i would be Grateful for any advice. Thanks!
3,298
Can't tell from the drivers seat either. The hood needs to be open and listen for the area that the sound is coming from! Check all the fluids as a first step, no maintenance history or mileage is given, so something may be low or at the end of life. As it's a first start issue have a helper start the car while you listen.
Best guess power steering, alternator, idler pulley, serpentine belt, water pump, transmission but difficult to know over a forum from a video in the drivers seat.
imidazol97
Top Dog
1,925
310
Take off the serpentine belt with a cold engine. I think you can't remove it completely, but
lay it so it's not touching the crankshaft pulley to catch on it. That means none of the
other rotating devices will be turning their bearings: AC, Power steering, water pump, alternator,
AND THE IDLER PULLER. You can run the engine for 15 seconds or so
My guess is your sound will be gone. Then shut off engine and rotate each of the devices.
Start with the idler puller. I think that's where you'll find the problem. You can replace the pulley
and its bearing without replacing the whole unit. The bolt is a reverse thread IIRC because the pulley
rotates in the direction that would help loosen the bolt normally.
Hope that's it. It's a cheap fix and easily repairable by DIY.
Good luck.
Mad_Coachman
Active Member
1,578
565
Long Island
2002 LeSabre Limited
Are you referring to the high pitched sound that occurs at the 30 second mark until when you shut it off? If so that sounds like a vacuum leak. Does your HVAC work properly?
Full Member Since 2005
8,731
1,137
SE
Has the PCV valve ever been replaced? The video shows it to be a 1987, or is it a 1997 as first mentioned?
Buikckforever
LeSabre 2001
Im sorry, it is a 1997 LeSabre, i got the Title of the Video wrong. Sinne I just got. my LeSabre, I have Not replaced anything yet. It also got 147k Miles on it
Buikckforever
LeSabre 2001
Yes thats the Sound I´m referring to. Ok there might be a vacuum leak… Would this explain That the Sound is More present when the vehicle is in PARK or NEUTRAL and when accelerating?
8,731
1,137
SE
The engine should be pulling 19-21 in-hg at idle and if you accelerate, the vacuum will drop. So therefore, under acceleration, if you have a vacuum leak, the leak noise will dissipate.
BuickGirlFromMars
616
I say try the belt trick first, I think it could easily be a worn pulley and an OEM belt that is accentuating the noise even further. But it could also be vacuum, it was hard to hear but I picked up both what could sound like those different things.
