2 easy questions Speakers / Headlights
springthemadcap
Hi guys,
I own a 2006 lacrosse and I got 2 simple questions.
First, I want to change the front and rear speakers in the car. The rear ones are pretty easy to take out but for the front...I cant figure how to do. Do I need to disassemble the whole door cover? Or simply pop out the plastic grille ? I need help on this one.
Also, my low beam bulb is dead. I feel stupid because you need to take out the whole headlight assembly and I can't figure how to do it. You lift the 2 bars (the plastic and the metal one) then you remove the plastic clip between the two lights, and then ? I'M stuck :confused:
Thanks for the help!
Arnie K
The bright light fitting is the same as the dim so take it apart first to see how the cover screws off/on and the light comes out. Both the cover and the bulb are removed by a standard twist to the counterclockwise and replaced by a twist to the clockwise. Now to the dim light. You have to release the entire light assembly before you can remove the screw-on cover to reach the light. On the rear edge of the light unit closest to the engine is a white locking tab. Pull that tab up just to the point where it releases…pull too far and it locks again. Next, locate the other locking bracket which is a metal bracket in the center-rear of the light assembly. This bracket is held down by a screw. Remove the screw with a 10mm wrench. Lift the bracket just like you did the white bracket. You should now be able to pull (or pry) the entire light unit forward a little. Depending on the size of your hands this might be enough. If not, then you need to release the plastic bumper assembly to give you a little more space. This is done by removing two expansion locking pins, one that holds the little plastic strip down between the bright and dim lights and one that is located inside a rubber bumper on the engine side of the light unit. To remove these locking pins, pull or pry up the little tab in the center of the pin just like you were pulling a nail by the head. That should give you more space.
Pedal Commander
