2000 Buick LeSabre Custom Aftermarket Head Unit
ShaneLeSabre
2000 Buick LeSabre Custom, previously owned 1990 & 1995 Buick LeSabre Limited
i am now considering just temporarily replacing my HU with an updated OEM since my CD player isn't working and it has no cassette. I was just curious if the 2000-2005 OEM units are all cross-compatible since they have that unique plug-and-play bus in the back. for reference this is the OEM unit I want to get, but the description says its for 2003-2005.
Mad_Coachman
Active Member
1,292
408
Long Island
2002 LeSabre Limited 148k miles
Of course it is fully compatible. The interface in these vehicles is commonly referred to as "Dock and lock". I'm truly sorry that you weren't able to get your Kenwood to work. Perhaps you should go with the Axxess/Metra adaptors next time instead of PAC. Let us know when you're ready to try an aftermarket unit again.
The only issue that you might encounter is unlocking the radio. It may say LOC on the display. If that occurs then you should search this forum for the procedure to unlock it.
CorvairGeek
3.8L Member
441
118
The Gem State
1996, 92 Buick Century
The '03-'05 radio requires a command (specifically the Dash Interface Module - DIM) from the serial bus to power on. It also is VIN matched to some modules on the bus and does go LOCKED as soon as the ignition is turned to ON (ACCESSORY can be used for functional testing as the VIN check is not performed). It stays locked until battery power is removed, or is matched with a GM Tech 2 tool.
I've not tried this particular radio in the 2000-2002 car that originally used the big, single knob radio. I suspect there may be no serial bus connection (purple) to the radio in the earlier car. I know the Dock & Lock used a ribbon connection in the earlier body, but changes to actual wires to the Dock & Lock from '03-'05.
2,923
There are 3 different face and types for 2000, 2001 and 2003 to 2005 along with part# with different sound source and option in systems. If looking at used matching the current model would possibly be the best route.
Another post on the LOCK display if it comes up to be mindful of.
Mad_Coachman
Active Member
1,292
408
Long Island
2000-2005 are the same interface. I just checked my old unit in the garage. 2 knobs. It will be plug & play or more accurately Dock & Lock. :cool:
Still have to unlock it though.
2,923
The OP radio options, 2 knobs 2000-2000 H AUDIO SYSTEM Buick Lesabre
