2001 - cruise shuts off when I turn headlights on...
danielzink
2001 Park Avenue
Kind of a strange deal...
Car runs great.
No CEL's.
Cruise works just dandy 98% of the time....
If I'm driving along and it's dusk....starting to get dark....
As soon as I reach down and pull out the headlights knob on the dash...the cruise disarms...and will not re-arm unless I push the headlights knob back in...
Any ideas ?
Thanks, Dan
2,591
First guess is that the brake lights may be shorting out when turning on the lights telling the system that the brakes are being applied, but it's only a guess. Check the brake lights including the center if any issues show up when turning on all the lights. Others may have addtional suggestions on the problem.
BuickGirlFromMars
321
Park avenue cuts cruise control of it detects a traction or stability event, wheels slip on the drive axle (enough random variation to be erratic, but maybe not enough to do stabiliteak(could indicate unreliable speed readings)
Brake pedal switch application(check adjustment) the switch I believe is meant to cut off BEFORE alights illuminate. So to allow cutting with your feet and not hitting the lighra(I prefer this to the switch)
Also if the engine is misfiring I believe it will too. Let me find a manual
BuickGirlFromMars
321
So other than driver inputs like the switch and brake pedal, I think the only change for 2001 would be addition of stabilitrak controlling off but don’t quote me
BuickGirlFromMars
321
Here’s an adjustment to check
2,591
OP said it cuts off when he turns on the lights which is usually and doesn't appear to relate to the other possible items, but there may be more reasons also.
BuickGirlFromMars
321
I
Im thinking it’s either a shared ground on the pillar firewall or he’s jumping positive power when using switch to a fircuit that’s a kill for the cruise, either by drawing low or the pcm commanding lff
Mad_Coachman
Active Member
617
162
Baldwin, New York
2002 LeSabre Limited
Car runs great.
No CEL's.
Any ideas ?
Thanks, Dan
I thought all big GM H bodies had auto headlights. My first one (1997 Bonneville SE) had them as well as my 3 Olds Eighty Eights from the same generation. One would assume that a top of the line car such as the Park Avenue would have auto headlights as well. I haven't had to manually turn on my headlights since buying my Bonne in 2003.
BuickGirlFromMars
321
his sensor could be bad which reverts the headlights back to work on RAP but otherwise manual. so 10 minutes they would stay on and cut off to savbe power. im pretty sure a super bone-stock park avenue in maybe 97 could be had with manual headlights.. but i am pretty sure t/s was just standard mostly
