2002 Buick Rendezvous Help me fix
savannahpickott
2002 Rendezvous
So I bought the car a week or so back mostly cosmetic things that need to be fixed some electrical but there was no manual when i got the car. it is 2002 2WD currently i am trying to figure out the lighter fuse, back windshield wiper, and defrost for back window, also not as important but is it possible to fix the cruise control ?
Len
2003 Buick Rendezvous all-wheel drive
Len
The fuses you're looking for are located on the passenger side in the front look at the side of the center column under the dashboard you'll see the opening next to the left foot of the passenger some of the fuses you're looking for or inside there good luck I have a 2003 Rendezvous that will not shift into 4th gear has other problems but I can live with them but I really need 4th gear. Good luck again. Underneath the covers over your fuse boxes you'll have a chart you don't have to have your manual but of course it always helps.
TollKeeper
Brighton, CO
For the 12 Volt socket under the radio, its either fuse 45 or 48 under the hood fuse panel.
For the rear wiper/washer, its fuse 32 at the interior fuse panel.
For the rear defrost, its a combination of 2. Fuse 21 on the interior fuse panel, and relay #20 on the interior fuse panel
For the Cruise Control, its the under hood fuse panel #31
These are not guaranteed to fix the problem, but a good starting point.
Buick Rendezvous Fuse Panel location and description
Pedal Commander
