2003 Buick park avenue base
Jopz
Hello, site
I just purchased my 03 P.A base model, it needed freon,but now i notice only the passenger side blows cold, driver side is like warm. Can anyone point me in the next steps ,to fix this problem? Thanks, Jopz
Alan 55
312
102
Florida
Congrats on your purchase of the 03 Park Avenue! The symptoms that you describe is that of a system that does not have the correct amount of Freon. The most accurate method of correcting this is to take it to a shop that offers AC service. They will remove the Freon and vacuum down the system to remove any moisture that may present. Now the most important step of weighing in the exact amount of Freon in ounces that the manufacturer call for.
If this does not sound good to you there are some do-it-yourself methods that may work but not have the accuracy by the AC shop method. If you decide to use the small cans of refrigerant, please know that it is very easy to overfill the system which causes cooling problems. It will be necessary to add a tiny amount of refrigerant at a time with a thermometer in both the driver and passenger vents. By watching the thermometers as you add a small amount of refrigerant at a time you will hopefully see an equalization of temperatures.
Jopz
Thanks, well i dont think they had any freon if so very little, so i had put a big can of ac pro, when noticed warm driver,cold passenger.
Drakito
77
Southern Utah
2003 Park Avenue Ultra
The Park Avenue has a dual climate system. The passenger and driver sides can be different temps. The main controller does the driver side. It will also do the passenger side if the passenger control slider is in the center, if it is not, the passenger control overides it and goes to the temp selected. In 2003, the passenger control is over by the passenger door and is a simple slider.
What you described is a common problem with the blend door actuators. There are several in the PA, 1 for driver side temperature, 1 for passenger side temperature, 1 for air direction, and 1 for re circulation. The actuator can be stuck, out of alignment, or can be burned out. Either way you will need to unmount it. I haven't had to do mine YET, but there are multiple posts on this forum about how to do so.
Here is just the first I found on a search. door actuator install
Jopz
Appreciate your help
