2003 rendezvous passenger HVAC blend door location
hennit_seebo
Rendezvous and a LeSabre
I've come to the realization that my rendezvous blend door actuator is not working properly. I am getting toasty warm air from the drivers side,but on the passengers side I am getting cold air. This seems to be a common problem with rendezvous. Does anyone where this little devil is and the procedure for getting to this blend door? Do I have to pull the whole dash or can I accesses it from the glove box, or floor boards. Any advice would be helpful. Thanks!
hennit_seebo
I removed the bottom black shroud on the floor and I can see the blend door actuator but now I can't really get the glove box off. I removed all the visible screws and it still seems helded in by something. I just don't want to break it because it seems like very fragile plastic. Anyone have any tips on getting the glove box out?
hennit_seebo
Just for everyone elses information in case they have the same problem as me. I removed the glove box by removing the screws in the glove box and the 5 or 6 metal retaining clips. It popped right out and I could see the blend door on the left side. It turned out that the electric actuator was ok and worked fine. The plastic arm popped off the door arm. I have no idea how this happened but there seemed to be a lot of tension from the spring. So I reattached the arm and took off the spring and it seems to be working just fine now!
Golferdude
I have the same problem...toasty warm on the left two vents and nice and cold on the right two vents. After I get the glove box out it will be evident what I am looking at. I was having a problem during the winter when I turn the temp to hot it would shut the air flow off to the vents... It was suggested to take the arm off connected to the actuator I believe. Now that it is hot I need to get cold air to all vents...so I will look this weekend and see if I can tell what you are describing.. Is the spring in sight or behind the plastic?
DevilDog911
2002 buick rendezous
I have a 2002 brick rendezvous. Looking for help coding new key after I replaced the ignition.
