- 548
- 95
- 28
- 03 PAU 202k, 04 PAU 90k, 97 PA (salvage 185k), 99 PA (sold-now 170k), 2K PA (sold-now over 200k).
Ok...couple things going on with a 2003 PAU with 202k miles.
Was headed up a hill in MT today; give her some gas, car downshifts to 3rd and over the mountain we go no problem for the supercharged engine. That is how it normally works...
Today...downshifts to 3rd and stumble...stumble...no power... bucking...make it (barely) over the hill at about 40MPH. GREAT...Tranny maybe...?
Got home removed the supercharger belt and the car runs & shifts fine ...so...must be a problem with the supercharger.
The snout pulley has a "little" play; could it be the coupler? The car has been noisy for about a minute after startup, and I read that could be a sign of the coupler going bad.
Maybe the valve bypass? The round canister looking thing? I know when my boost solenoid went out on another car it did not do this.
Is my supercharger gone?
Went looking for codes & discovered a P0131 Oxygen Sensor code (no check engine light was on). Scanner said "passed & failed." Recently replaced the Fuel Pump, filter, & Fuel Pressure Regulator so I just cleared the code and will see. Maybe will replace the front oxygen sensor if it comes back.
Since the car runs "ok" without the supercharger belt, the 131 is probably a different problem...(?)
Any advice on the supercharger issue...?
