2004 Park Avenue hot in the city
ParkAveCore
21
2005 Buick Park Avenue
Hey everyone! First post here!
Just bought a 2004 Park Avenue, my first Buick since my 73 Riviera I had in the early 2000’s!
It’s running an 1/8th line over half on the temp gauge in the city and 1/4 under on the freeway.
I was going to do a thermostat swap and a radiator flush tomorrow.
Do you all think that will fix the issue?
Thanks everyone!!
Full Member Since 2005
9,747
1,678
SE
Welcome to the Buick Forums. Is one coolant fan running with the AC activated when this happens? When the engine reaches 225°F, both fans should run high speed. If you choose to replace the thermostat, be sure to get a Stant fail safe and if it ever fails, it will fail in the open position.
Silvermist
87
Do you have an OBD II scan tool where you can look at live data and see what the actual temperature is? It seems like GM put the gauge there to indicate cold or "oh shit" because there really is nothing telling what the temp actually is, lol.
ParkAveCore
21
Welcom to the Buick Forums. Is one coolant fan running with the AC activated when this happens? When the engine reaches 225°F, both fans should run high speed. If you choose to replace the thermostat, be sure to get a Stant fail safe and if it ever fails, it will fail in the open position.
Thanks for the advice!! I will get that fail safe.
Both fans are running high speed with the AC on
ParkAveCore
21
Lol!!! No I don’t have the tool but I have a mechanic that’s not too expensive, just always try going as a last option.
Sounds like there a chance it’s possibly not actually overheating then.
ParkAveCore
21
Thanks everyone!!
I really rolled the dice with this car. 184,000 on the clock but well maintained. I hope it’s a 300,000 mile prize winner
9,747
1,678
SE
The Engine Coolant Temp sensor (ETC) could also be giving false readings to the gauge.
Silvermist
87
Ya I honestly think your car is running at normal temperature but I can't be sure and I don't want you to have any problems because of me. The only way to accurately check is to use a code scanner that can read live data. Of course a tech II is the best but expensive. From my experience, my coolant temp gauge will get close to 3/4 (5/8 really, lol) in city traffic just sitting there. I live in north east Ohio so I'm happy with the stock thermostat during winter. You can always put a cooler one in depending on your location.
Silvermist
87
I'd say a trip to the mechanic now will be much cheaper than a trip to them if a head gasket fails. The mechanic can see everything on their scanner and proceed from there.
ParkAveCore
21
Oh wow 5/8 and still running good, definitely not a precise gauge for sure
Silvermist
87
Oh dang, I need to hit her up, I just followed her, thanks!!
She retains knowledge like I retain weight. Very smart. I do have factory 98 park avenue dealer repair manuals coming in the mail. It's not pertaining to 2004 but there are a lot of things that can be cross referenced and hopefully help.
ParkAveCore
21
Thanks for being so cool to the new guy Silvermist, much appreciated!
BuickGirlFromMars
1,808
does your temp readout(digital) kinda jive with mine here? The car SHOULD be able to get that far with a needle, the ones in mine have to be understood as not straight on shots, so they are more to the right of center than youd realize. To me, sounds like cap, thermostat, plugged line between reservoir and radiator, and condition of coolant should be inspected.
See the orange fanta? Dex cool when nice and clean mmmmmm thats what you want to see not the previous pic(water and the scale that existed in there for years)
Something to note is the readout on the IPC And the gauge will both not match the live data of a scan tool
A scan tool will likely go to higher numbers amd change all the time. Thats intentioned to make the cluster "smooth" it out since it only
Oh its precise. ish. the upper temp range the resistance values get some wider gaps just llike when really cold. the max temp, or close
Does your car have a IPC with the slew of buttons on the left side or do you have only 2 buttons? to the left of the IPC that is.
