parkercw
- 0
- 0
- Buick
I have a 2005 that I was driving last summer, it began having an intermittent starting problem but after turning the key a few times would start and run fine. I never had a security light on. I left the car parked for a month or two and when I went to move it again the security light is flashing on the dash with no crank. The light cycles from security, fuel, and battery. I changed the ends on the battery cables, (the ground was horrible) and charged up the battery. I've tried doing a 30 minute relearn and checking all fuses with no luck.
It seems like it must be the ignition or the actual passkey 3 module. Has anybody else had this problem? It seems very hard to just bypass the passkey 3 so that I can move the car. The car needs a windshield and I paid less than $500 for it. I'm debating on scrapping the car or finding a way to
get it to the dealer if the fix is under $1000.
