2006 Lucerne Keyless Entry Not Working
rxa4929
Have a 2006 Lucerne and all functions of the Key Fob recently stopped working. Have gone through the reset procedure and replaced the batteries in both remotes but no luck. Any suggestions?
Jalong
I'm having the same problem with my 2006 Lucerne. I tried to reset by pulling and replacing the fuse, but when I try to relearn remote keys, instead of giving me an activate label, it just blinks once and goes back to the same screen. Maybe I'm pulling the wrong fuse (display).
fath2004
I had the same problem. Both my remotes stopped working at the same time, so I was rather sure the problem was the receiver and not the remotes. On another forum a posting said that he found a loose wire in the trunk between the two speakers. I looked there and saw a device with a wire connection. It was not loose, but when I unplugged the wire and replugged it, my remotes immediately worked again.
vintage42
Louisville, KY
2008 Lucerne CXL V6 Gold Mist
... On another forum a posting said that he found a loose wire in the trunk between the two speakers. I looked there and saw a device with a wire connection. It was not loose, but when I unplugged the wire and replugged it, my remotes immediately worked again.
We just got a 2008 Lucerne, and the first time I shoved something into the back of the trunk it snagged a harness that was hanging low. I tucked it up, but am now resolved to go back under there with a handful of long zip ties and take care of all the harnesses and wires that may be unsecured.
Lucy613
Lucerne
Several years after your post I had the same issue today with 2 fobs not working. Unplugged and plugged connection in trunk, fobs are now working. Thank you!
DaveO
2006 Lucerne
Same exact problem here with my '06 Lucerne...Same fix worked great!!! Thanks SO much! I'm sure this saved a bundle for the dealer to do the same 5 minute repair.
G-196097
i tried this and it worked like a charm...thank you soooooo much !!!!!!
Pedal Commander
