2008 Buick Lucerne
dromein
2008 Buick Lucerne
I am looking to install an aftermarket radio in my 2008 Buick Lucerne, but I’m having trouble finding the correct wiring harness. Any help is appreciated, thank you.
Ropchips
10
2006 Lucerne CXS
Yep. Crutchfield is the way to go.
Most likely will need idatalink Maestro setup to retain all oem features.
Hope you're not a newbie to installs because it can appear daunting if installing an entire system.
But for a head unit only....just take your time and read and follow the install and setup instructions.
3,438
If you go to Crutchfield.com they have two different interface cable harness on the base system or if it has the HK amp unit. Somewhat plug and play but be mindful that each head manufacturer may have addtional instructions regarding installation.
