2010 enclave won’t start won’t crank
Aj45vb
Enclave
Had the car only a year. In one month Couple times when starting car would take forever to start or would shut right off. Battery saver would be active for bout hour then shut off. Then finally it just won’t start. Won’t crank. Battery is fully charged. Changed out the ignition switch. Ignition relay is fine. The ground is connected.
when turning key can hear fuel pump. Lights come on. Passenger airbag light flickers. No crank
What else can it be?
Staff member
5,085
782
What is the battery voltage?
Have you removed and cleaned the battery connections?
Have you checked the battery connection at the starter?
Have you checked the battery ground?
You switched the relay with another one?
Aj45vb
Enclave
So thankful my husband never gave up. He can hear the clicking of ignition switch so he followed it. Got behind the airfilter found couple more grounds. He cleaned them off and it started up.
I got my car back
