2010 Lacrosse ac clutch not disengaging
coolmeiser
This spring my Lacrosse CXL 3.0l air conditioning decided to start acting funky. Pressures are 44 and 185 No cycling observed at gauges. Clutch never seems to disengage, wont even turn with engine off and key removed. Climate control doesn't cool the car adequately on the highway (moderate hit and miss cool air) and blows warm air in town even set on max cool. I'm no trained mechanic but would expect the clutch to be disengaged and turn with out using a cheater bar on it. Haven't tried that yet... Unless one of you more educated fellows can enlighten me, I'm looking at a compressor swap including dryer replacement and system flush. I've done it on my former Taurus SHO so it's not out of my skill set, I just flat out don't want to if i'm missing something simple if you know what I mean.
Rich B.
87
Minot, ME
The twin fans cool the radiator? Or the fan for evaporator, may be 2, I can’t say on that.
940
The low pressure switch may be bad and is keeping the clutch engaged, just another option to consider. Sorry I don't have any information on how to test it.
coolmeiser
Did you try to put the heat on full hot to see if the clutch disengages ?
Unfortunately heat works wonderfully... Thanks for the thought
I’d try first operating the compressor solenoid with a direct 12VDC as problem may be with temp control instead (should be located with evaporator fins. Can just picture a compressor change, recharge and still not working?
Applied 12vdc to the solenoid (located on bottom of compressor) with no change in symptoms.
364
The compressor is known as an PXE16, similar to the V5 in that is a variable piston stroke compressor which has no clutch cycle off/on when the A/C request from the control is on. What was the ambient temp when you checked high/low side pressures? My best guess is, that the low side seems to be on the high PSIG side of the scale, which would indicate low refrigerant. More info about the variable stroke compressors in the link below.
Variable Displacement Compressor
Rich B.
87
Minot, ME
Interesting, this is similar as far as the compressor remains engaged either way. Compressors for air tanks sometimes run continuous with load engaged and free wheeling through mechanical pressure switch, before the electronic idea.
Learned something new here also, good topic.
CorvairGeek
3.8L Member
270
71
The Gem State
1996, 92 Buick Century
The Sanden compressors with electronic refrigerant control can have poor cooling like you are describing too. They can be erratic in cooling. Turning them off and all can create different rates of cooling, as seen when running and watching the gauges (depending on what the failing valve does each time, besides the dynamics of a variable displacement compressor). Be very careful if adding refrigerant. GM only recommends charging by weight, and has for decades.
While it is extremely refined and great for NVH, the phrase a 'boar with teets' comes to mind.
coolmeiser
looks like ill be taking the car into my local mechanic to have the refrigerant evacuated and, hopefully weighed to see how much r134 is in this car. will update when I have more info.
G-142739
Replaced the compressor and air is ice cold again! I pulled that little solenoid out of the old compressor and, sure enough, that little guy wasn't opening properly. I may have been able to save a bunch of cash by just replacing that part but wanted the air back quickly and the compressorwas readily available unlike the solenoid.
Zeroboostbuick
372
S.W. Ontario Canada
Good to hear all is good. Thanks for the update. I went 1 summer without AC and never again !
Pedal Commander
