2010 Lucerne steering issues
ROA Preacher
Lucerne
I have a Lucerne CX which is new to me with 65000 miles. When I go around long curves to the right such as on the Interstate. I get the sensation as I am driving on grove concrete. Any suggestions?
2,776
Bearing, brake, strut or worn suspension components are a guess until something gets inspected.
G-471951
Thank you for your help. I have replaced the sway bar bushings and the front brakes. The struts seem good with no extra bounce. I have not heard a bearing make any noise.
ROA Preacher
Lucerne
I have changed the front brakes and replaced the front sway bar bushings and end links. I even had different struts put on with the same result. Thank you for your help.
2,776
Has the axle shaft or bearing been inspected? Has a technician taken the vehicle out to be tested?
G-728385
No the axle has not been inspected. But a mechanic has driven the vehicle. He has not determined the cause of the problem.
