2011 Buick lacrosse A/C kit
9
2011 Buick Lacrosse
Thread starter #1
Well my A/C only blew cold when it was cooler outside. Long story short i was told by 2 different mechanics one was firestone. That i needed to replace my compressor, condenser etc. I recently read that horizontal condensers could not be flushed only replaced. Ok so I bought a kit from UAC. Universal Air Conditioner. My local shop were selling the kit for $465.00 Which is the condenser With Dryer, compressor O rings, expansion valve. I figured they had to be somewhat descent because my local shops were selling UAC as well and everyone was sold out for a week or two. So I called a distributor and paid $303.00. and got it in about 3 days. Im waiting on my mechanic to call me tonight to pick it up. I will let you know how it goes.
Has anyone had this problem with their A/C yet.
How good Is UAC.
9
2011 Buick Lacrosse
Thread starter #2
Well I got my car back and the A/C is blowing as cold as ice but i assume the better test will be tomorrow when the temperature gets back up to 100 degrees.
58
48
#3
Did anyone check the low & high side pressures before replacing all of those parts? I hope it is doing well and holds the charge for a long time!
358
75
S.W. Ontario Canada
#4
I can't live with out AC. Glad you got it sorted.
9
2011 Buick Lacrosse
Thread starter #5
Yes Yes both did. I thought the first guy was trying to rip me off at first but when i heard it again. I was like it must be true. $508.00 for everything so im not too hurt about it. It could have been worst
358
75
S.W. Ontario Canada
#7
You and me both. It gets a little hot in Texas
I bet... I'm in Canada LOL but we get hot here in South Western Ontario and the Humidex is what makes the heat 100 times worst.
A week ago we reached 120 with the humidex !
Edit: It was actually 117 f //// 47 c
358
75
S.W. Ontario Canada
#8
I have to say that under $ 600 out the door for a new AC system with installation is a very good deal.
9
2011 Buick Lacrosse
Thread starter #9
Yeah Im happy myself. I got them from Pitstopauto. Everyone in town was sold out. Even sellers on Amazon. Pitstop sells their parts on Amazon as well. They also price match. I put together a kit that was cheaper than theirs so they matched it.
358
75
S.W. Ontario Canada
#10
The little effort you put into the shopping sure is worth every penny saved.
109
17
2016 LaCrosse
#11
A happy ending, good job. I can't believe it, central Maine and we hit 118 degrees last week and that's in the shade. Humidity at 70 percent. I have never seen it that hot here before this summer. A/C in Maine, guess never say never......
9
2011 Buick Lacrosse
Thread starter #12
Well its not a Happy ending yet. I guess I celebrated to soon. Well it got back up to 99 degrees today. And it blew hot as if the clutch didn't engage. So I'm wondering if it is a switch, relay, sensor issue as well. As soon as it got cooler outside it blew cold again. Any suggestions.
358
75
S.W. Ontario Canada
#13
You could be able to tell if the clutch is engaging or not. Best to do with another person pointing a flashlight at the compressor while you turn it on and off.
Should be able to see visually and hear audibly when the clutch engages.
There usually is a low pressure switch on car AC systems that disables the clutch when there is not enough pressure in the zystem ( too little freon ).
109
17
2016 LaCrosse
#14
Roger that on unhappy camper. Is it plausible the controls are set to a defrost mode vs cooling mode? Any thought process I put into my own such controls i continously screw up. It's why children are so successful learning computers, won't try to outthink or second guess on what they think things are supposed to be or do:(
9
2011 Buick Lacrosse
Thread starter #15
Yeah I'm thinking the switch maybe the problem. Then again it blew ice cold when it was about 85 degrees outside. So the clutch does work. And my mechanic called me yesterday to check on it and said he only put 2.5 cans in my car.
kevinande
Seems like common sense, but make sure there are no leaks. Last month I paid $1134.00 to fix a dead compressor. In my younger days i would have done it myself, but I am no longer interested. Apparently these compressors are notorious for failing. I have just over 90k on mine and this was its first major issue and then a dead battery so all in all not bad for a 5 year old car. I hope you get it working. My car was without air for a grand total of 1 day. As far as I am concerned in Texas if the A/C does not work the car is broken.
9
2011 Buick Lacrosse
Thread starter #17
Your a
Almost correct. Its been working fine today. But I will see
