2011 Buick LaCrosse CXS rear windows and doors issue codes U154A and U1548
Sstevieboy0208
Cincinnati Ohio
2011 Buick Lacrosse
I have a 2011 Buick LaCrosse CXS and all of a sudden my rear windows stopped working they won't work from the master switch or from the actual individual switch and strangely at the same time the rear doors won't trigger the dome lights when open nor a message on the dash that they're open. Basically as if the car not recognizing the the back 2 doors at all. I checked fuses and relays and no luck. Any tip or help to guide me in the right direction will be greatly appreciated. Thank you all.
Chris Heinen
2010 LaCrosse CX
That's a puzzler. The following OEMDTC bulletin doesn't specifically mention Buick, but the codes/symptoms match...
Sstevieboy0208
Cincinnati Ohio
2011 Buick Lacrosse
Some of the symptoms are in that thread. I will get to it today and post the results. Thank you
1,137
Codes U154A and U1548, is U154A a U1544? Also on most GM it's the master control in the driver's door that the wiring harness connections control for passengers windows run through so that may need to be checked. Control and harnesses may be a option to consider looking at.
This is why I asked about the one code#
Service Information
Sstevieboy0208
Cincinnati Ohio
2011 Buick Lacrosse
Service Information
U154A Is present but not 1544. But will keep that as a second option. Thank you I truly appreciate all inputs but the first one have more symptoms that I have which makes me lean towards it.
547
U154A 00​
(K9 Body Control Module) LIN Bus 4 Lost Communication With Device 10 (S79RR Window Switch - Left Rear)
U1548 00​
(K9 Body Control Module) LIN Bus 4 Lost Communication With Device 8 (S79LR Window Switch - Right Rear)
Sstevieboy0208
Cincinnati Ohio
2011 Buick Lacrosse
U154A 00​
U1548 00​
So does that mean that it is the master switch lost communication to the 2 rear ones ?
1,137
That may be the first place to check as it's something common on GM's when the MC isn't working it will cut out other windows functions. If not you can check the other list posted.
1,137
Yeah that's a head scratcher, I'm not familiar with the harness layout, but I believe the door actuator handles door open trigger lights and warnings. There was a recall on the 2014 Lacrosse on a splice in the driver's door that had different items not working because of corrosion, but seems it might be a different problem on yours.
Sstevieboy0208
Cincinnati Ohio
2011 Buick Lacrosse
Well I found out that it's all one circuit so I will check the switch then the harness. My guess is that if the back 2 doors have no power to them that will cause all since it's on circuit supply for all
nglauer
2013 Buick Lacrosse AWD
Did you happen to take your car into the dealership? I don't mean to hijack your thread, I just purchased a 2013 Lacrosse AWD with a some what similar problem. My driver's switch doesn't illuminate and the only switch that works is the drivers window. Also, the mirror switch doesn't work. Oddly though, the windows all work from their own switches? I purchased a new GM switch and had the exact same results. I haven't tried a replacement mirror switch yet, but believe I'll have the same outcome. I am hoping your findings may be relevant to my issue, even though they are slightly different. I did have a lot of water in my driver's floor board, probably 1-2 gallons? I'm not sure how it got there, but it was extremely wet. I'm hoping it's not an issue with the wiring harness (assuming the one running back the drivers floor is related to the passenger switches). As a side note, my door locks work fine.
Thanks!
Nick
Sstevieboy0208
Cincinnati Ohio
2011 Buick Lacrosse
Thanks!
Nick
Mine the rear windows are not working at all. And I think there might be a harness that got disconnected as well as I have never had the issue with water inside the car. but I will keep you posted on my finding as this next few days I might have the time to take another look before I take it to the dealership.
nglauer
Sounds great! I appreciate it. I hope I am able to locate my leak and figure out my windows as well. I really don't want to take my car to the dealership outside of warranty.
Sstevieboy0208
Cincinnati Ohio
2011 Buick Lacrosse
I will start with the drain pipes for the sunroof brother. Check them out make sure that they're draining right.
nglauer
My sunroof drain lines appear to be working fine. we've had quite a bit of rain the last few days, and no new water accumulated in the floorboard while I had the carpet pulled up. The majority of the water appears to be gathering in behind the brake panel. if the weather cooperates this weekend, I'm going to rotate the wheels and tires and take the inner fender well out on the driver's side while doing so. Hopefully I can see where the water is entering there. I suppose I could also have a windshield that is leaking, but I don't see any signs of moisture etc showing up around the windshield
1,137
I'm not sure if this is the same problem on your Lacrosse, but others have had the HVAC drain cause leaks in the interior.
