2011 enclave rapid turn signal indicator
Walter7543
2011 enclave
I replaced my burnt out rear right turn signal with a compatible LED. I did the other side as well. All of my exterior lights work but I’m still getting a rapid turn signal indicator for both left and right turn. Why? Is it because I used a LED in which it draws lower voltage?
JoeBlog
101
Wichita
You need to put a resistor in the circuit. LED’s don’t draw the amount of power the system expects, so it mimics a burned out bulb.
