2011 LaCrosse -HELP PLEASE: Warning Lights after changing the alternator
Markgarland
2011 LaCrosse
So my wife had the Battery Protection Activated screen pop up, she pulled over and had AAA tow the car home. We found the alternator was not putting out, so I went to the parts house and bought a new one. The new one is charging the battery just fine now, HOWEVER we are getting the Service Brake Assist, Service Stabilatrack, Service Park Assist, and the Brake light and ABS light are now on all the time. Before the alternator went out, I had no warning lights. This car doesn't even have Park Assist so I don't know what that is even about. When you pull up on the Emergency Brake, you can hear it engage and then the minute you take your finger off, it disengages. Hoping someone can shed some light on a way to reset this without having to take it to a dealer. Thanks in advance for any help you can provide. Again, like I said there was no issues with anything before the Battery Protection kicked in.
444
How did you determine the new alternator is working, did you use a handheld voltmeter at the battery?
MarcM
Monadnock Region, NH
08 Lacrosse Super
I know on my Volvo, I had to hold the negative and positive terminals together for about a minute to discharge the ECM voltages holding information. Not sure if that's the case here.
Markgarland
2011 LaCrosse
I didn't try that, maybe I will and see if that works. Really trying to avoid the dealership, not really in the budget right now.
Markgarland
2011 LaCrosse
So, I did try holding the positive and negative cables together after having everything unhooked. Still have the exact same lights on. This really sucks but I guess it's gotta go to the stealership.
JoeBlog
101
Wichita
Those might be related to a low voltage condition from the bad alternator. You could just try going to an auto parts store and seeing if they could clear the codes with a scan tool, now that the original condition has been corrected.
