2011 Regal CXL Turbo transmission fluid type?
jonathangortz
Hello , how are you guys doing?
My car is due to change transmission fluid for 100,000 miles maintenance but I am face with a dilemma. There are two fluid type.
Automatic Transmission 2.4L -
Dexron - VI Automatic Transmission FLuid
Automatic Transmission 2.0L -
Automatic Transmission Fluid, GM Part NO 19256039
I have 2.0L however the GM parts are expensive. I need 5 quarts I believe but can I use Dexron-VI Auto Trans Fluid instead ? Or are there any other alternative I could use? Thanks
Staff member
5,563
888
You have to use the correct fluid, I assure you a transmission repair will be more expensive than the fluid. You need a fluid compatible with an Aisin Warner transmission.
