2015 Buick Encore Back Hatch
Thread starter #1
dutch1001
2015 Encore
Hello,
I have a 2015 Buick encore that has a back hatch that will not open all the time.
All the doors will open when I hit the remote to open everything, but the hatch does not.
Is there an easy fix for this or another way to open the hatch?
Thanks
Thread starter #4
dutch1001
2015 Encore
Hello,
Thanks
Lubricating the hatch made no difference.
1,377
353
This may be something to look at:
"Open Vehicle Settings in the Configuration menu to change the remote lock and unlock settings".
Unless the lock switch on the door has become inactive, as I do not own one, is there a rear door button in the driver's area and if so does this work or also intermittent?
Some other Buick models had a switch to open or lock the rear door, not sure on this model, if so you should see if it's on all the way and not partial.
g_864506
I just went out to give it a try, but no luck at all. Thanks anyway!! It's going to the dealership on Monday.
