2015 Lacrosse will not always start
buick15
2015 buick lacrosse v6
car does not always start and is doing this more often. it acts as if the battery is low, but put new battery in and still does the same thing. it will sometimes say theft deterrent or stabilizer.
is there a starter relay or module going bad. the is a remote type start keyless style. also replaced batteries in the remotes. thanks
Pops2010
7
LaCrosse
I had this issue on my 2015 too. The difference with mine was that once it was started, the door locks would unlock and lock non stop and then the theft deter light would go on and then service stabilitrack would come on too. The dealer never could figure it out.
buick15
i hear ya, that is why I am trying to find out if there is a relay or switch causing the problem.
209
did you have the charging system tested and have a test for a parasitic drain or just went and replaced the battery?
buick15
yes, had the battery checked, charging system, and starter pull. what is weird is if a relay, it sometimes goes on and on at a slow pace turning the motor over and the it either stops complete of the car starts to run
buick15
yes my point that the starter clicks over and turns slow and the either shtus down or the motor starts running and is doing this with a new battery ase well as the old when. I have a spare battery that I just bought for another car . that is what I put init. . but this is more than old school theory since this is keyless. I noticed that the click is coming from the fuse area which has several. realys. so I went on rock auto to see what the relays are and there is a relay for the ignition that tells the keyless button to work. I think that is the problem. it may be going bad. will order that and see what happens. under $10 so no biggy.
499
Has the actual starter itself been checked along with the wires? Kind of hard to tell if that's been done by the descriptions, nothing old school here it's basic trouble shooting. If the starter is bad or going, positive / negative ground wires loose or corroded it will have signs of what you have described also, just another option to consider.
