2017 envision Remote start
Huntr0302
2017 envision AWD
I have recently purchased a 2017 envision awd It came with both remotes.
However presently only one will remote start the car. The second remote works fine for everything else but will not work to start it remotely. Was hoping someone here might have an answer for this problem.
NormT
Turbo-4 power!
1,349
72
48
OH-IO
2018 TourX
Are you making sure you are selecting lock before hitting start on the second remote?
510
Did you follow the setup process in the owners manual? Replaced battery's? Did it work before and stopped?
Huntr0302
2017 envision AWD
Thank you both for the replys and suggestions Norm T yes have been selecting lock before selecting start.
2007lucerne this remote works for everything ekse Ie... lock unlock starting rear hatch etc.. just will not work the remote start.I have replaced battery and the other remote works normally for remote start.
510
If you never used it before to remote start, then how would you know if it's good or its been setup? Did you go through the setup process in the manual?
