Sign up to remove ads. We'd love to have you amongst our ranks! Just click the Register button below!
buick forums
The Premier Community for Buick Owners and Enthusiasts
Join us! It's free!
buick forums
Past Lineup: Lucerne | Roadmaster | Regal (Old) | LeSabre | Century | Park Avenue | Riviera | Reatta | Grand National
Current Lineup: Cascada | Verano | LaCrosse | Regal | Enclave | Envision | Encore
Buick Forum: Heat is warm - NOT HOT
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Join Date
    Jan 2017
    Posts
    11
    Rep Power
    Sign up to remove this ad
    So I have a 2005 Buick LaCrosse CXL with the dual temperature control zone thing. I'll turn the heat all the way up to 90 degrees but the heat is still just a little warm, not even close to hot. I don't think it's my thermostat or the heater core. I installed a new radio with OnStar adapter and steering wheel control adapter, but the steering wheel adapter wouldn't work so none of the buttons work on the steering wheel (doesn't really matter to me) could this be an issue? Doubtful but maybe. Should I try flushing the heater core or something?
  2. #2
    Join Date
    Feb 2014
    Posts
    42
    Rep Power
    Re: Heat is warm - NOT HOT
    Is your coolant topped up?
  3. #3
    Join Date
    Jan 2017
    Posts
    11
    Rep Power
    Quote Originally Posted by JFD View Post
    Yes it is topped off
  4. #4
    oldschool is offline Full Member My Buick(s): '03 Buick LeSabre, '07 Allure CXL
    Join Date
    May 2010
    Barrie, Ont
    Posts
    167
    Rep Power
    Every fall for the last three I've had to back flush my heater core to get heat. Usually notice it in November as the weather turns cooler.
  5. #5
    dbris is offline Full Member My Buick(s): 2011 Lacrosse CXS
    Join Date
    Feb 2012
    Los Angeles
    Posts
    155
    Rep Power
    6
    Did the heat work correctly before the new radio was installed? If so, then it may well have something to do with the radio installation.
  6. #6
    Join Date
    Jan 2017
    Posts
    11
    Rep Power
    Quote Originally Posted by dbris View Post
    I am unsure because I installed it in the summer and only ever used the A/C which worked.
  7. #7
    Join Date
    Jan 2017
    Posts
    11
    Rep Power
    bump plz help
  8. #8
    BuickLacrosse is offline Full Member My Buick(s): 2006 LaCrosse CX 3.8L
    Join Date
    Jan 2014
    Out in the sticks
    Posts
    112
    Rep Power
    Did you open the rad and check the level? If not it would probably be my first stop. Lots of people just check at the overflow jug. BL
  9. #9
    Join Date
    Jan 2017
    Posts
    11
    Rep Power
    Quote Originally Posted by BuickLacrosse View Post
    Yes I checked and its all fine
  10. #10
    Join Date
    Apr 2015
    Posts
    329
    Rep Power
    Remove this ad
    I had to blow out my heater core several times until I had a proper coolant flush done. With the engine warmed up, both hoses should be hot. If one is not, the core is clogged. Sometimes you can blow out the blockage. Take care, because you can damage the core and replacing it is not a pleasant job.
    If both hoses are hot, then you need to look at the temperature door actuators. In a dual zone system there is one for the drivers side and one for the passenger side.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Buick? Check out your options at the links below:
Genesis Motors
Check out what the competition is up to. The Kia Stinger is a large sport-oriented hatchback in the mold of the Audi A7.
