Sign up to remove ads. We'd love to have you amongst our ranks! Just click the Register button below!
buick forums
The Premier Community for Buick Owners and Enthusiasts
Join us! It's free!
buick forums
Past Lineup: Lucerne | Roadmaster | Regal (Old) | LeSabre | Century | Park Avenue | Riviera | Reatta | Grand National
Current Lineup: Cascada | Verano | LaCrosse | Regal | Enclave | Envision | Encore
Buick Forum: 9 speaker wiring question
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    PkAve01's Avatar
    PkAve01 is offline Buick Newbie My Buick(s): Buick 2001 Park Ave
    Join Date
    Apr 2017
    Posts
    Rep Power
    Sign up to remove this ad
    I have the 01 Park Ave Base with 9 spkr setup. I want to keep the oem but in the factory amp I want to switch the rear deck signal to the rear door and the rear door to the rear deck. Does anyone know the wire color code for the rear door speakers?
  2. #2
    bigsky is offline 5.7L Member My Buick(s): 97 PA Base (salvage 185k), 99 PA Base (sold 140k), 2K PA Base (sold 120k), 03 PAU 155k, 04 PAU
    Join Date
    May 2006
    Montana
    Posts
    385
    Rep Power
    12
    Re: 9 speaker wiring question
    Quote Originally Posted by PkAve01 View Post
    Left Rear Door: White (-) Pin F16 at amp & Tan (+) Pin F15. This is named the "Left Rear Midrange Speaker Output" from the amp.
    Right Rear Door: Red (-) Pin F13 & Tan (+) Pin F14. Right Rear Midrange Speaker Output.
    This is from a 2002 Service Manual.
  3. #3
    Maylar is offline Full Member My Buick(s): 1999 Park Ave Ultra; 1985 Olds Delta-88 Royale
    Join Date
    Jun 2011
    Connecticut
    Age
    65
    Posts
    172
    Rep Power
    7
    Assuming it's the same as my 99 Ultra - Be aware that the rear deck 6X9's are "sub woofers" and the rear door speakers are just 3.5" full range speakers. The OEM amp has circuits to direct the appropriate frequency ranges to each set. Bad idea to switch them. You won't get any bass out of the 6X9's and the 3.5's will probably blow out.
    Dave from Connecticut
    1999 Park Ave Ultra
    All the goodies
  4. #4
    Join Date
    May 2006
    Montana
    Posts
    385
    Rep Power
    12
    Quote Originally Posted by Maylar View Post
    Yes the OP should be aware or hopefully knows how the system is set up from the factory.
    Just to mention options; I disconnected the rear door speakers, the front door tweeters, and the center dash speaker. I then upgraded the front door woofers with 5 1/4 coaxials. I kept the door tweeters connected for a while, but prefer the sound without them. This setup keeps the soundstage up front. Also, the headunit is a Pioneer.
    The rear "subwoofers" put out pretty good bass IMO, and are an upgrade from the 6 x 9's used in the 6 speaker factory setup.
  5. #5
    PkAve01's Avatar
    Join Date
    Apr 2017
    Posts
    Rep Power
    I sincerely would like to thank you all for your help. I am new to the scene and is impressed with the PA. I picked up a pair of pioneer 6x9 with a 27hz to 37,000 hz range and with a 92db sensitivity. I also seen a small 5.25 Tang sub-woofers that I feel could fit in the rear doors to give added bass without overpowering the clarity of the system. I feel the car will sound better by having the full range signal from the rear doors pumped from into the rear deck. I have not decided on whether to combine the rear deck sub signal wired into one sub to go into the rear deck OR send the 6x9 sub signal to the rear doors where I would put the 5.25 Tang subs. I think this arrangement would bring the PA closer to a real concert sound. Any ideas would be greatly appreciated.
  6. #6
    Join Date
    Jun 2011
    Connecticut
    Age
    65
    Posts
    172
    Rep Power
    7
    Again, the factory amp has filters that direct specific frequencies to each speaker. Full range with hi pass (limited bass) to the front, reduced power without bass to the rear doors, and bass only to the 6X9 subs. The only way to take full control is to replace or bypass the factory amp. Fortunately all radio and speaker wires come back to the trunk and plug into the amp. The connector is the same as the one for the radio with a few more pins being used.
    For my system I used a 4 channel amp and external equalizer. 2 channels to the front speakers, 2 channels bridged to a 10" sub in the trunk, and Boston 6X9's off head unit power for the rear channels. The rear door speakers are disconnected. Some day I'll do something about the front center channel.
  7. #7
    Join Date
    Jun 2011
    Connecticut
    Age
    65
    Posts
    172
    Rep Power
    7
    Quote Originally Posted by bigsky View Post
    The front door speaker mounts are very lame plastic boxes that are tuned to the OEM speakers. I tried putting some high end components in the doors and they sounded horrible. Ended up taking those boxes out and mounting speakers to the outside of the doors.
    BTW what head unit did you use? I was told by Crutchfield that all Pioneer decks are too deep to fit into the PA dash.
  8. #8
    Join Date
    May 2006
    Montana
    Posts
    385
    Rep Power
    12
    My deck sticks out a bit, but with the trim ring on... it fits fairly flush to the dash trim and looks fine IMO. The deck I have is a single DIN unit around 10 years old. Some owners have installed Double Din decks and have gotten extra depth by modifying & removing the rear bracing for more room for the cables.
    I did not have a problem and routed the plug-in adapter harness under the deck. The mounting kit I used had a blank space under the deck; many kits have a "pocket" which just gets in the way. I also found an antenna adapter with a right-angle plug.
  9. #9
    ffhamm is offline Buick Newbie My Buick(s): Buick GN, Park Avenue Ultra
    Join Date
    Apr 2017
    Posts
    Rep Power
    BTW what head unit did you use? I was told by Crutchfield that all Pioneer decks are too deep to fit into the PA dash.[/QUOTE]
    See my post: Crutchfield told me that there were some pioneer double din radios that would fit in my PAU. However I wanted and NEX series. They said it would not fit. It did. I used a Metra mounting kit and cut the back pocket like you have to do for any double Din radio. I also had shave a little plastic on the front bezel underneath the trim plate to allow the faceplate to rotate to put a cd in it.
    Jeff
  10. #10
    Join Date
    May 2006
    Montana
    Posts
    385
    Rep Power
    12
    Remove this ad
    I wanted to follow up with some pictures. For the deck, with the blank plate removed, you can see the adapter harness & wiring along with the steering wheel buttons adapter.
    I may put the OEM speaker grills back on, but will probably remove the thin piece of felt-like material on the backside of the grill.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Buick? Check out your options at the links below:
Genesis Motors
Check out what the competition is up to. The Kia Stinger is a large sport-oriented hatchback in the mold of the Audi A7.
