Troylee
- 0
- 1
- 1984 Riviera
I have an 84 rivy with T.S.solenoids in the drivers side trunk. Right signals work fine but when I turn on left turn signal, I get nothing. I’m getting power to the right two pin connector that goes on,off,on,off... but when I set the meter on L turn signal two pin connector it has power, just no on and off. So I’m getting voltage but no blink, tried switching the two relays, doing same thing. Pulled both relays, still doing same thing. Looked under radio and dash for front flasher, don’t see one. Main fuse box in interior by drivers knee has aluminum round thing in upper left corner but it doesn’t make noise when turn signal is on. TS fuse is good. Any tips for troubleshooting this? Thanks in advance!
