9 Speed transmission 2nd-3rd gear barely any difference.
powermax
10
Buick Regal Sportback 2019
I was manually shifting my 9 Speed and noticed there is barely any difference between 2nd and 3rd gears it's almost like a virtual shift from a CVT. I drove a Lacrosse with the 9 Speed same thing. Did anybody noticed that?
PrincipalDan
623
93
Gallup, NM
2018 Regal TourX
The 8 speed isn't much different in that regard. Plenty of situations where the 8-speed Aisin transmission skips from 1st to 3rd because there isn't that much of a hill of beans worth of difference between the two ratios.
D2R
354
Michigan
2019 Regal TourX Essence
12345678
5.2503.0291.9501.4571.2211.0000.8090.673
It looks like quite a jump from 1st to 3rd if 2nd is skipped. 😲
I need to take her more for the ride to get a feel for her. (Not trying to sound like a pervert...)
On the other hand, the 9 speed does look very close to each other.
(Is it even realistic to have a direct drive ration all the way up at 7th gear...?)
PrincipalDan
623
93
Gallup, NM
2018 Regal TourX
[/URL]
12345678
[/URL]
what's always in my head with the automatic transmissions above 6 gears is "how many overdrives are there? How many does one engine need?"
D2R
354
Michigan
This is my first automatic vehicle with more than 1 overdrive gear and a direct drive. So there is still the learning curve on how to deal with her.
The other vehicle I had that has more than 1 overdrive gear did not have a direct drive, but that was a stick shift where I get to choose which gear. I still miss that car though.
1st2nd3rd4th5th6thReverseFinal
3.1662.0501.4811.1660.9160.7253.2504.529
fng
99
Delaware Ohio
Car and Driver magazine's road test of a FWD Sportback noted that 3rd had very little difference from 2nd. They stated that the transmission is programmed to skip 3rd when accelerating briskly.
PrincipalDan
623
93
Gallup, NM
2018 Regal TourX
I don't know which (if any) GM transmissions fall under this umbrella but there are a few multi speed automatics currently in production which rarely utilize 1st gear - it's too "steep" to use unless you are flooring it from a dead stop.
Ctrcbob
366
Regal Tour-X
My E350 Mercedes 7 Speed was like that. Always started off in 2nd unless i manually started in 1st. (Or tromped on it).
PrincipalDan
623
93
Gallup, NM
2018 Regal TourX
Alex Dykes (Alex on Autos) will usually call out when a change in transmission for a vehicle/engine combo is simply about the published 0-60 times more than anything that benefits the consumer on a daily basis. He's called out some cars where a manual trans has been replaced by a DCT as being simply for the sake of published 0-60 times.
powermax
10
Yes they did mention it. I just wonder what would be the benefits of having such a close ratio.
