95 Roadmaster heated seats not working
BradH
1995 Buick Roadmaster
I have a 95 Roadmaster with the heated seat option. Neither one will work. The fuses are good but the indicator light will not even come on. Does anyone have any experience in this area?
robert graham
12
The heating wire panel under the upholstery has broken wires and need replacement…If your seats need to be re-upholstered then that would be an ideal time to replace those heater panels….I know about this because my seat heaters quit working and I checked with the upholstery shop…
Griswold
11
Buick Roadmaster
Check the switch first (that was the problem on mine). As I recall, if the bulb burns out the heater won't work. The switch has very small gage wires so it must operate a relay or something, as a lot of juice would go through the heater itself.
