Zerepdivad
- 0
- 1
- 98 Buick Century
Hi there,
I'm working on my 98 century. I replaced a few brake lines on the vehicle and am having difficulties with bleeding the system properly.
I am able to bleed the FL and RR and only fluid comes out and it comes out strong. The FR and RL are acting as though there is still air in the system and it comes out weak. I am able to bleed at the bleeders on the abs controller connected to the master cylinder but the one that controls the FR and RL seems to have the same issue as at the wheels so it seems like it still needs to be bleed some more.
I borrowed a Vetronix Tech2 from a friend to try and do the autobleed procedure but it does not appear to show that option when I put the information for this car.(it does show the option if I out in a different vehicle)
I have also read that many people simply go drive in gravel or a wet road and slam the brakes to activate the abs but it seems that I have a bad wheel sensor in the wheel bearing keeping me from being able to do that. (Code c1225)
I have read about people hardwiring the motor to run and I am thinking of doing that but I am not sure which wire on the motor to energize.
Sorry for the long post but any help is appreciated.
Thanks!
Thanks!
