98 Lesabre Door panel issues
Thread starter #1
1998 LeSabre Limited
I have a 1998 LeSabre and i recently took the door panels off to do speakers, i used a christmas tree puller but the foam that the clips mount into on the panel got messed up in some places. Does anybody know what i can do to miunt these clips? Also along the top by the window the panel clips on but when you slam the door it will unclip in one spot but can just be pressed back on. Anyone have any advice?
1,404
361
Not sure what you mean by "foam" as it's plastic on the door panel. There are replacement clips if they are no longer working and as with the top it's a matter of alignment when reinstalling. Here's a video on how to remove and replace the door panel.
If the panel is damaged at the clip mounting points, 1 get a new panel or 2 glue the clips in.
