• In the 1980s and 1990s we used AOL and Usenet. In the 2000s there were forums and message boards. In the 2010s - and until the very near future - social media. Something new is coming for Buick owners... Become an early adopter of what's next by SIGNING UP HERE. Your email address will not be sold or used in any way other than us communicating more details as we prepare for launch - and we will not communicate often.
A/C Evacuation & Recharge - 2001 LeSabre - Doing this myself - Questions
JGBuick
143
2001 LeSabre Touring Edition
Update: Refilled system with r134A and it's better...but I wouldn't say it's "Cold".... Maybe 50-55degs from the thermometer.
I'm heading out this afternoon and will see what happens on the highway....
Interesting to note that final gauge readings are not what I thought they would be. High side is lower and low side is higher...
I've done everything but replace the evaporator. (Could that have restrictions over 20 years?) Who knows.... I'm hoping the system balances out but from here.... I dunno....
JGBuick
143
No outside temp display on this car. If it has one, I have never seen it. There's a bracket with nothing on it... and the last pic has something attached at the bottom. Sensor? Dunno! No loose pigtails as far as I can tell. Maybe your car being a different model?
Very interesting question and here's what I can see looking down:
I am bewildered now. Looking for a pigtail etc. Where would the sensor lead to? The compressor?
JGBuick
143
Question for those with this model - Who has a sensor in this location?
John Canon
186
1997 Lesabre Limited Gran Touring Suspension
On the Chilton page, the manual HVAC does not have an Ambient Air Temp Sensor, but the automatic HVAC shows the sensor mounted in front of the condenser, with the pigtail and connector coming from along the bottom.
JGBuick
143
So... I don't have an automatic HVAC. I'm guessing because of this, I would "not" have this connection. Would that be an accurate observation?
John Canon
186
Yes. In the automatic HVAC the ambient temp sensor is part of the feedback loop to maintain a constant inside temp. In the manual HVAC you are the feedback loop to maintain a constant inside temp. Push the lever to the right ... oops too far, push it back to the left a bit. Ah-hh that's about right.
lbear
2004 Buick LeSabre Limited Celebration
531
303
I tested my 2004 LeSabre AC today. It was 75F outside and quite humid. Here is my reading:
37F out of center vent
lbear
531
303
Also my hose mod worked great. No more drips on steering hose and frame.
JGBuick
143
Must be nice!!! I can't get my temps into the 40's!! Ugh.... everything by the book and twice no less!
Maybe... maybe it really is a blend door "Calibration"?? Or... maybe something is blocking the evaporator itself?? I can't think of anything else...
I'm wondering if I can clean the evaporator without undoing the latest mods etc...?? Adding more refrigerant "may" also fix things.
The coldest it got to day was about 53degs and that was driving down the highway at 75mph. Come to a stop and the temp goes up...
John Canon
186
Try this test: start the cold engine and let it idle with the AC set to max cool. Then check the outlet temperatures before the heater core can warm up. Check every few minutes as the engine warms up. If the outlet temperature starts to increase maybe the blend door is allowing some flow through the heater core. If the outlet temp stays low ... well, my thinking is done for today.
JGBuick
143
Good idea... I can try that... I've read that when a higher reading is on the "low side" and a Lower reading is on the "high side" it may have something to do with the accumulator. (???) At this point, I have replaced almost everything. (No evaporator). My observations (so far) is telling me the pressures are "off". But??? Does a new compressor have a chance of being bad? If the clutch is engaged, isn't it compressing?
I really am (Mentally) taking a break from this as it's a bit numbing to figure out the "why".... I do appreciate everyone's ideas though! ;)
Full Member Since 2005
9,252
1,419
SE
Well, I was wondering the same thing? Going back about 105 post, I saw where you had the compressor replaced & nothing else. It could that the debris in the old system, contaminated the new V5 compressor and the control valve! When the compressor was replaced, was it a new one, rebuilt & what brand? Where was it purchased? Compressor warranty states, that if you can not provide proof of replacing the expansion valve and accumulator when installing the new compressor, the warranty is VOID!
JGBuick
143
Yep, I bet the orifice tube us full of trash
Original "had" some nominal debris and THEN the new compressor was installed along with a "NEW" orifice tube.
I replaced this tube "AGAIN" with equivalent tube so the system is on it's third orifie tube. The tube before this had zero signs of contamination but I replaced the tube anyway.
JGBuick
143
ulycyc
198
Long Island, New York
1987 Turbo Buick, 2001 Park Ave Ultra
I'm wondering if when you removed the orifice tube a few times one of the 0 rings stayed in the port. If the orifice tube doesn't seat or the port has crud, old 0 rings or whatever fused in there it can effect your pressure problems. This used to be a big problem with mid/late 70's GM cars
JGBuick
143
Thanks! Never thought of that!! It's worth investigating. I feel like there's a restriction somewhere... but where?
JGBuick
143
You could temporarily bypass the heater core so no heat gets into the cabin. If after that the ac is significantly colder consistently then you have a blend door issue.
Worth checking for sure... I should probably replace the heater hoses anyway... Sheesh... who would have though this whole venture would be so complicated.
