A/C Issue
1992RML
1992 Buick Roadmaster Limited
It was in the mid 90's yesterday in Dixie Land and I drove the 92 RML for 150 miles to many small Southern towns the A/C blowing ice cold the entire time and I recalled the Buick service film I watched on Youtube and thought I would check under the passengers side carpet for moisture and taaaadaaaa there it was I also looked the the drain tube area and no elbow in place or maybe with time it fell off . Now I will have to find one. Check link below it comes up at 6:03 of the film .
1992RML
I found an original OEM drain plug on RockAuto I think there is only 5 left . The Link is below. 1 Other problem could be the seal on the evaporator case which I hope is not the case . I will let all know once the part is installed .
1992RML
I received my Evaporator Case Drain Hose installed it and went touring today and checked for moisture under the passenger side carpeting . Well its now off to plan B . There was still moisture still under the carpeting . I will have to get under the dash now !
57caddy
92 roadmaster
Remove the evaporator cover and RESEAL it. Also, put butyl 3m seal around the tube as it sticks out through the firewall, fill the gap, the elbows are available on Ebay, part # 22542866
