A/C issue
Tropicalcats
Lacroose
2014 Enclave and I’m having this issue
this does not happen all the time but has happened 2 times in the last couple weeks.
with the car running and the A/C on, the light on the A/C will start to flash and the temp gauge will go to no reading. If I shut the car off and start it back up everything is back to normal.
needs some ideas before I take it to a shop. Maybe something I can just fix.
1,204
When you say temperature gauge I assume you mean Air temperature not engine temperature.
A guess would be the dash control unit is failing.
