ABS light TRAC OFF light
Thread starter #1
kingpin
2003 Park Avenue Ultra
2003 Ultra been having this recurring problem. ABS and TRAC light come on intermittently. They reset each time you turn the car off then may stay off 100 miles or more then come on again at any time. I'm getting a C1232 code on my scammer, shorted or open circuit on my left front speed sensor. Also had another code in the past that wasn't there this time something about variable speed on my left front wheel unable to determine wheel speed something like that. So anyway I figure the left front speed sensor is bad or possibly there could be a broken wire somewhere going to the sensor not sure. But unfortunately as far as I can tell the speed sensor is not replaceable you have to replace the whole Hub. And then should probably have the front end realigned, which was just recently done by the previous owner, the car drives great.. But the Hub shows no signs of being bad and I don't really want to replace it if it isn't. On the other hand winter is coming and I don't like the idea of no ABS brakes and no Traction control on slick roads. Any ideas on what I might try short of Hub replacement. I've done the Hubs before and it is not a problem to do them just wondering if I'm missing something and might be able to fix short of that. Thanks.
Alan 55
Florida
I have a feeling that it is time for a new hub bearing. If you want more evidence you can raise the vehicle and give the wheel a motion check. We are looking for any inward/outward movement by pulling/ pushing on the wheel with hands at 9:00 and 3:00 positions.
I love the 97-05 Park Avenue but this is one of the weak area’s in my opinion. This type of vehicle is still my favorite of anything on the road.
Zeroboostbuick
239
S.W. Ontario Canada
More common than most think, the wire loom going to the wheel hub speed sensor...
Here is a video showing exactly where the problem is... skip to the 14:00 minutes if you don't want to watch the whole thing.
This is valid only if your wheel hub bearing speed sensors are not the real fault.
Zeroboostbuick
239
S.W. Ontario Canada
Fella in the video shows how to diagnose the problem, so worth watching the whole video.
Thread starter #5
kingpin
Yes, Thank You after watching this one and another like it I'm thinking that's very likely where the problem is. I'll investigate further. Thanks again.
Thread starter #7
kingpin
Well as I go further I'm running into some stumbling blocks. I have a friend who was a Mechanic at the local Buick dealership. I talked to him about the problem and he said it was most likely a break in the wiring harness somewhere as mentioned above. Well I got a new AC Delco harness for it and when I went to put it on I noticed the Black wire coming off the new plug is attached to the B side of the plug and the White wire is attached to the A side of the plug. But the old one on the car is reversed Black on A White on B. Then to complicate things more the Black and White wires from the plug wire into a yellow and Blue wire going into the wiring harness that eventually connects to the EBCM. Not sure if this harness has been replaced previously and they got the wires reversed because there is what looks like 2 splices in the wires. I need some kind of diagram showing which wires the yellow and blue go to.:rolleyes:
Thread starter #9
kingpin
Thank you so much for that diagram. The left front sensor on my car the light blue wire coming off the harness is wired to the B side of the plug which according to this diagram is backwards.
Zeroboostbuick
239
S.W. Ontario Canada
You're welcome.
Your hunch was right about the wires possibly being backwards.
Thread starter #12
kingpin
Well wired it up the way I believe to be correct. (Reverse of what it was.) and so far no lights on the dash so hope that fixed it. Time will tell. Thanks for all the responses.
Thread starter #14
kingpin
Well unfortunately the problem has returned. After about 2 weeks and 800 miles of driving suddenly the lights came back on. They started coming on instantly, before I even moved the car and would stay on. Reset each time I shut the car off then come right back on as soon as I started driving. Then drove 72 miles to work lights on all the way. Shut it off got off work drove 72 miles home lights never came on till I came to a stop at home then suddenly came on again. So now I'm thinking probably the speed sensor and the hub will have to be replaced. Still getting codes c1221 L/F wheel signal 0. c1225 L/F wheel speed variation. c1232 L/F wheel circuit open or shorted. Also have OEM codes in the history u1040 lost communication with the ECBM u1301 data link hi voltage bus shorted to bat. and c1298 PCM indicated class 2 serial data link malfunction. I think some of those codes may have come on when I started the car with the sensor unhooked. So right now I'm leaning towards the wheel sensor. Talked to my ex Buick mechanic friend and he said in all his experience he didn't believe he had ever replaced an ECBM because of a wheel sensor code and he thinks that's probably what it is. Keeping my fingers crossed as those ECBM's are expensive.:(
Thread starter #16
kingpin
Well replaced the Hub so far so good. Time will tell. Thanks.
