AC compressor pigtail
Alleyboy
1972 Buick Skylark
I need help, what is this wire called and where does it plug into I know the pigtail end plugs into the AC compressor but I can't find where the other end plugs into
141
the flat plastic connector with the resistor plugs into the ac compressor to activate the clutch.
are you sure the other round connector is the same wire?
it looks to me like the power wire going to the blower motor.
do you see a disconnected wire hanging from the blower motor?
Alleyboy
1972 Buick Skylark
Yes I'm sure I took the wiring harness apart and that's where it lead I checked and couldn't find where the other end connects too
