Frampton
- 122
- 43
- 2003 buick lesabre custom
Does anyone have any info on adding a rear swaybar to a 03 lesabre? TX.
I have 2256016s and I do have FE1. I want to retain the soft ride and only get a rear swaybar.I think Frampton needs to decide if he wants to stiffen the front as well.
I drove a Limited 03 Touring before "ordering" our Limited Celebration with 16 inch wheels and
fairly wide tires. I was not as impressed with the touring as I thought I would be. but that was not
the cornering or curve taking, but rather the struts/shocks. They seemed to work in a way that the
car was pitchy front to back on the test road I was on.
I'd like to know what size rims and tires Frampton currently has. I didn't think our 03 was so bad
on the cornering. Maybe there were different OEM sway bars used on the front or maybe it was
due to the Michelins and 16 inch rims 6 inch wide, fairly good for that day.
There are optional bushings for the end links on the front bars that can reduce the give and thus
stiffen the ride and I believe there are different bushings where the bar is strapped to the frame
for less give in the rubber. That might stiffen the front without the trouble of replacing the whole
bar, which requires taking off a strut as I read one post.
Thanks. That's what I'm looking for. I can't seem to find what else I'll need to complete, brackets, bushings...GM is only listing the 20757300 which if looking for new it's seems to be the only option from GM as the soft ride. If you look at the list of vehicles it was used on it's a soft ride sway bar. When shopping check various GM and other aftermarket sites as the price will be all over the place plus confirm shipping costs on the GM as some can be to high. Also the hold down brackets, bolts and links should be considered.
11? And I would need 5 also...#2,3,4 and #11 on the diagram, you would need two of each.
Stabilizer Bar & Components for 2003 Buick LeSabre | GMPartsDirect.com
www.gmpartsdirect.com
Hmmm. Don't see a number 11#11 is all of those parts in the stabilizer link which normally comes as a complete unit of 5-10.
Ok. I gotcha. I was looking at the last pic.Post #2, not sure what you are looking at.
Yeah. Do you have a pic of ur car?No problem just wanted to all be on the same page, plus I'm just too lazy to open another window LOL.
Before my sayber, I had a 07 lacrosse. Nice car. Loaded.Yeah. Do you have a pic of ur car?
