Air Ride compressor
Nasty Al
2004 Le Sabre
2004 Buick Le Sabre, I hear a winding noise from the rear standing next to the car while the car is running. A humming pitch of a noise.
Three or four years ago I replaced the rear air shocks with standard air shocks. Did not hook to the auto levelers system. I pump up the shocks manually if needed. Just recently started with the noise on longer trips. Short trip today and no noise, I thought I'd pull the fuse so the compressor for the air ride would not be able to come on. Fuse or relay? anybody? which one?
Nasty Al
2004 Le Sabre
I pulled both from under the seat fuse box ,fuse 65 and relay55. time will tell if that corrects
the issue. They are not marked what they are for? You must have a wiring diagram.
thank you for taking the time to look that up.
Nasty Al
2004 Le Sabre
Are the fuses labeled on a diagram on the inside of the cover for the fuse box?
there is but those particular fuses , i think it's abbreviated ELEC electric?? but states not for what ??
anyways I pulled them both
Staff member
5,591
889
ELC Electronic Level Control
