Any Warranty Work in your Regals?
72buickgs
11
2019 Regal Sporthatch, 1972 Buick GS
I had to have the fuel purge valve replaced at 4000 miles on my 2019 regal 2.0 T, a few weeks ago. Also got an oil change & filter. All fixed.
FavaBean
256
DE
2018 Regal TourX Essence
What where your symptoms of this issue?
saab93driver
165
2019 TourX
The dealer replaced my radio when it wouldn't accept the update to 22.9. The first replacement radio arrived in a couple of days but was DOA. A second was ordered and received in a couple of days and installed. I have my live traffic back but lose XM presets (greyed out) sometimes, no, I've not done a reset yet. That's extent of warranty work I've had done in 18K miles.
Gracie615
36
Just curious. Did they tell you that it is caused by trying to overfill the fuel tank? Such as trying to click in more fuel after the tank is already full? That's what my Service Advisor told me. Just wondering if they gave you a cause.
Otherwise replaced lower control arms, had a kinked heater core hose, had to have them take off and re-install the lower side moldings near the rear wheel on the driver's side, had issues with the radio and the screen which turned out to be a defective wiring harness we waited 18 weeks for. After that, GM bought back the car.
fng
Delaware Ohio
2018 Sportback with 18,8xx miles here. No warranty work, just a couple of oil changes and a wheel alignment.
72buickgs
11
The overfilling of the gas the gas tank was serious issue with Ford cars going back a couple years. A friend owns a 2018 F150 with the same problem and it took several weeks for Ford to admit to the problem. The symptoms he experienced were the truck had to restarted several times, from rest, then it would run.
There was noting said by the Buick tech about overfilling. With the design of the filler tube mechanism, the problem should be reduced.
bgow
Can you walk me through how to find what update I'm on with my radio please
ready2fly
13
Tampa, Florida
2018 Regal Sportback Preferred II
I am getting a new liftgate on my 2018 Preferred II Sportback. Factory liftgate had a weird rattle inside that my dealer could not fix.
72buickgs
11
Was there an option, a power button inside these cars to unlock the liftgate?
