ASS went away?
garbageguy
165
Regal TourX 2019
I thought I saw something on this in this Forum, searched for it to no avail, so starting a new thread.
The Auto Start Stop (ASS) on our 2019 TourX Essence - has had a few times when it wouldn't ASS, I thought that was due to the car having been unused a few days, cold weather, electronic steering wheel heat on. After driving 60 mi or so, turning off other electric loads, ASS worked as usual again (boo, but that's how it's supposed to work, I thought).
Last couple days we've put about 250 miles on, but still no ASS. Yes, it's cold here in the northeast this week, but do you think the battery is going, or something else going on? Instrument panel shows battery at 14.4 volts, (have seen it as high as14.9), not really ever below 14.
1,457
If you see those readings with the engine running that is the alternator output not the battery charge.
RegalMN
148
Minnesota
'18 Regal Sportback Essence
At what temperature does ASS turn off on the Regals? On our Chevy Cruze it won't activate under 40F. I know it's definitely lower than 40 for the Regal.
Rk54Strat
96
48
TourX
I had the same issues. Dealer changed the battery (under warranty) and the ever annoying ASS no works flawlessly.
Full Member Since 2005
8,731
1,137
SE
If the ASS went away with a new battery, you simply had a case of the GONE ASS.
LLninja
Greenback Troll #1
822
215
Illini country, surrounded by bean fields
2018 Buick Regal TourX Essence
Since your car is a 2018, and it’s cold, like others said, it’s probably your battery. My ASS still works, but I’ve got other weird symptoms like steering jerk when ASS wakes up and rear guidelines disappearing while backing up. i need to take a trip to the dealership to have that and my Bluetooth and squealing brakes looked at.
garbageguy
165
Regal TourX 2019
Thanks all - sounds like a trip to the Dealer is in order. We've been up in the Adirondacks last few days, and it (2019 TourX) sat in 10 degree weather the other night, it's snowing nicely now, low 30's. Started fine after the 10-degree sit. I don't have a trickle-charger up here, have been wondering if I should put the portable jump-start charger on it at all - thoughts?
garbageguy
165
Regal TourX 2019
One of the bulletted items in the TourX manual says ASS will operate when:
"The outside temperature is not in the required operating range."
But, no wonder I don't know - what is that range? That manual is not too helpful. Anybody know?
garbageguy
165
Regal TourX 2019
Back to the original topic of the OPs ass going away, I’m sure after all the Thanksgiving feasting, the ASS will come back :)
these days it seems to go to the wrong place
41
25
Reno and Plumas County CA
2019 TourX Essence
My ASS has gone away too, the car is less than 2 years old (since delivery that is.) If the battery needs to be replaced could this possibly be covered under warranty?
My car languished on the lot in Salt Lake nearly 2 years before I bought her, probably had a lot rot battery to begin with.
1,457
Should be 4 years bumper to bumper, check with the dealer.
FavaBean
522
93
DE
2018 Regal TourX Essence
Absolutely. I'm on my 3rd battery - all covered by the bumper to bumper warranty. I brought mine to AutoZone first for a free battery test and they confirmed it was bad.
D2R
843
Michigan
2019 Regal TourX Essence
I have never been to AutoZone to test the battery.
Do they use something like this where I can also test at home?
saab93driver
490
2019 TourX
When I worked in auto parts we used a load tester to test batteries. It needs to put a load on the battery, not just check voltage. This looks like a more modern version of what I used to use.
D2R
843
Michigan
Great. Found one on sale for under $30.
Thank you for the info. :thumpsup:
