Back seat bracket
lucy_2008
2008 Lucerne
2008 CXL, delivered to dealer 7/31/08 so I am guessing it was one of the last built for that model year. I just checked my back seat bracket that is reported to rub against the fuse box. My driver side bracket is much shorter than the passenger side. Looks factory, not cut. No chance to rub. No rub marks. What do you think of the theory that some cars just had the wrong bracket installed? Would be an easy mistake to make.
First post, great forum.
1,130
Not sure when it was caught by GM, but if the driver's side is shorter, or smaller in size, then the passenger it has the update. The other item was a lower height fuse relay for the fuel pump which was also part of the TSB and update, not sure if that may apply on yours depending on when it was done.
century76
2008 Buick Lucerne CX
Here are some pictures that I took before and after cutting the seat bracket. Hope this helps. DSCF3822s.jpg DSCF3823s.jpg DSCF3825s.jpg
