Ballast resistor
LARRY70GS
78
48
Oakland Gardens, N.Y.
98 Riviera, 70 GS455 Stg1
No, it has a resistance wire which does the same thing. It is only necessary if you are running points.
This is how the stock points system works. Extending from the firewall engine harness connector(below the brake booster), is a calibrated length of special resistance wire. This wire does not extend all the way to the positive side of the coil. In the harness, it is joined by a wire leading from the "R" terminal of the starter solenoid, and from there, it extends to the positive side of the coil. There is a shorting switch inside the starter solenoid. When the starter motor is cranking the engine to start, the shorting switch inside the solenoid, sends battery voltage through the yellow wire to the coil positive, effectively bypassing the resistance wire. Once the engine starts, and the key is released to the run position, the yellow wire ceases to supply voltage, and voltage flows from the firewall via the resistance wire. This drops the running voltage so that point life is maximized.
Having said that, your car is close to 50 years old. If you are not the original owner, it is hard to say what has been done to the car. If you want to test to see if the points system is working correctly, do the following tests with a voltmeter.
Connect the voltmeter between the positive side of the coil and ground. Turn the ignition switch to the run position. The reading should be 5.0-5.5 volts. It is important that the ignition points be closed for this test. If the points are open, the voltmeter reading will be full battery voltage. Bump the engine over until the points are closed, and check again. Again, 5.0-5.5 volts is the normal reading with the engine stopped, ignition key in the run position, and the voltmeter connected between the positive side of the coil and ground. The second part of the functionality test requires that you pull the coil wire out of the distributor, and ground it so the engine will not start. With voltmeter connected as before, crank the engine continuously, and observe the voltmeter. The reading should jump from the previous 5-5.5 volt reading up to 9 volts minimum. If it does not, it indicates a problem with the shorting switch inside the starter solenoid, or a wiring problem between the "R" terminal of the solenoid, and the coil. This will result in hard starting when cold.
